Weighed
    Weighed
    CSL (doh!)
    crappy "business" radio but nevertheless a radio
    leccy windows
    aircon
    aka "typical spec"
    safety devices rear cage
    rear seats removed
    Sparco Pro2000 seats on recaro sidemounts and sliders, alloy floor mounts
    Alcon/CSL Cup BBK
    Intrax 1K2
    (for now) std m3 wheels/tyres
    Full tank of fuel
    1450Kg
    Lardy!
    Mine was 1420 with 2/3 tank fuel, Aps and intrax but full oem interior, radio, aircon, etc so am surprised yours is so heavy? How much did the cage weigh?
      Jeez! that is surprising.
      Mine is almost identical but a good few KG off that.
        lardy indeed. What does 997 GT3 RS weigh pls?
          Originally posted by _Nathan_ View Post
          Lardy!
          Indeed! Mine was 1425kg with 1/2 tank when it was totally standard.
            Cage made from lead? :bigcry:
              Also remembered I have a supersprint full system with the lightweight back box.
              The cage is a safety devices bolt in job. So its no T45 svelte, but its rear only, I'd be surprised if it was more than 50kg.
              I reckon everyone is using generous weighbridges and dynos ;-)
                Mine and Nathans are corner weighted at Simpson Motorsport on a fairly regular basis. Are you sure your local weighbridge works OK?:gayfight:
                  Who knows eh. All I can say is that its a commercial one used by farms/truckers and gets inspected/calibrated regularly. The people who run it reckon its spot on accurate although I believe it rounds to 10Kg.
                  The evo came out at 1340Kg with 14l of oil and a full fuel tank. Full cage but lightened/stripped body. Probably about right.
                    Do you know what the Simpson scales said when you had your intrax fitted?
                      I would take a weighbridge reading with a pinch of salt.
                      A couple of years ago I tried to find out about calibration and accuracy of these. The nearest thing I could find was that the rounding, usually 10 or 20kg, was referred to as a "division" and that the weighbridge is within 3 divisions. For HGV's they allow +\-50kg before taking you off the road. Can be +\-150kg if one axle weighed at a time.
                      I'll add I'm no expert, but I fitted the cage...
                      It's not filled with lead, honest!
                        997 GT3 RS - 1375kg
                        996 GT3 RS - 1350kg
                        996 GT3 - 1380kg
                        As far as I am aware these are the weights and although you ask for the 997's weight it is probably fairer to compare the 996 as they were produced in the same era.
                        Pip
                          Originally posted by Pip1968 View Post
                          997 GT3 RS - 1375kg
                          996 GT3 RS - 1350kg
                          996 GT3 - 1380kg
                          Pip
                          So are we to assume these are also the weights by the book and not accurate when it comes to actually weighing the car? Be interested to know acutal weight of one on the scales like the RS with a cage etc
                          My CSL with cage + over half tank was c/weighted at 1385kg and more has been shed since.
                            You haven't been stripping all of the paint off inside and grinding all the metal panels down to bare, wafer thin sheet, have you ? :hahaha: :whistle:
                              Mine has AC, radiocd, xenon, rain sensor, AP racing front/rear and SS race lightweight, with full tank -> 1420kg
                              I didn't remove anything from the car (triangle, mobility kit etc).
