I had 165 out of mine on the Limiter, what will they do de restricted?
Top speed
I assume that was on a private test track you own BY the A30 was it!? :bigcry:Originally posted by grumpsI had 165 out of mine on the A30 Whiddon down (Rob) Limited, what will they do de restricted?
I've had 162'ish on the clock out of mine with plenty left :thumbs:
Edit to add mine has a factory re-limit on it but I personally haven't gone faster yet.
Hit the limiter indicating 165(ish) on the clock, which is a pretty accurate 155 on GPS. I have heard some rumours that 190 is possible with a delimit. Not sure how true this is since the CSL doesn't have the most aerodynamic front bumper in the world, although the gearing would suggest that it is possible. If someone has the gear ratios and diff ratio, I'll calculate the exact theorectical maximum speed.
Was that the BIT OWNED BY THE GERMAN AUTOBAHN COMPANY :whistle:Originally posted by grumpsI had 165 out of mine on the A30 Whiddon down (Rob) Limited, what will they do de restricted?
... rOB, ONCE EVERYONE HAS DONE THEIR BRAGGING IT MAY BE WISE TO ..UH .. AMEND SOME OF THE LOCATIONS TO FOREIGN ONES IF YOU GET MY DRIFT fook caps , plod has a way of causing people trouble at these speeds !
Ah ..Dan and Alex have already alluded to the above previously !
Unlss dropped from a great height, and even then 180 ~200 mph is about max for a free falling body in normal atmosphere !Originally posted by AlexGTT View Post175-180mph (GPS) is absolutely it. With a standard car any more is not possible.
I got up to that speed once , head down though !!:smokin: never done it in a car yet !
