camera mount in csl?
    Hi,
    what video camera mount is permitted at spa & destination?
    Suction mounts?
    Which should I buy?(camera weight is around 200g)
    Where can I put it without a roll cage?
    Cheers
    Originally posted by merell900
    Hi,
    Suction mounts?
    Cheers
    hi i have hague car mount on the rear headrest very good about £70 hope this helps
      Tis a tricky without suction mounts. For normal vid camera I thought shimmy's a harness bar was a great idea if not using the back seats, not sure why he's stopped using it unless it's just because his current place for bullet cam on rear view mirror is better. He's posted pics etc try search.
        Exactly how does that work on CSL seats? Rear headrests? :whistle:
          Thi is the best and cheapest site I've found. I use item 2 for bullet cam off the front rear view mirror buy only works if you have no rain sensitive wipers. Probably would work for small camera as well.
          The bullet cams I had weren't good enough to adjust light when mounted on harness bar so I ditched it.
          Guess rear headrest bracket is as item 14 above
          Here's my front one
            GoPro motorsports kit. Fantastic piece of kit. Can't recommend it highly enough.
              Although as he has a camera already a pretty pointless statement:smokin:
                something like this?
                will fit in the rear headrest?:banghead:
                  http://www.fastfilms.co.uk/fixed-camera-mounts.php
                  Here's my front one
                  I got a bullet cam but not record in full hd.
                  The new video camera is full hd.
                  I ´m afraid that the marshals do not permitted to use the ultra clam?
                  what do you think?
                    what do you think?
                    Ah at the Ring yes you are right
                      Thanks. Except that I bought mine after struggling to successfully mount a bullet cam/cables/mic etc. You have to remember that I am something of a tech numpty... :smt017
                        Hi,
                        Suction mounts?
                        Cheers
                        If its destination nurburgring you'll be ok well it was back in april folks were driving with suction mounts on there roofs and bonnets.
                          http://www.cameragrip.co.uk/acatalog...est_mount.html
                          Thats the one very good fits nice on csl rear head rest with camcorder think when i have some spare cash i will go the shimmy way looks good
                            :smt055
                            youve come to the right place:whistle: :thumbs:
                              I had one of those fitted until last week when i swapped over to bullet cams.
                              Anyone want to buy it? :whistle:
