Standard car with Spacers
    Best spacers are from Rogue engineering!
    Check out their website and compare the differences!
      What about these for you??
      They look like copy's of the H&R's
        Chris you have PM
          Hey Bryce, I've got 12mm all round and I'm on Standard Suspension mate. Don't have any photos at the moment, something I'm distinctly lacking off these days. Car is a disgusting sight right now, I should be ashamed.
          Looks and feels much better with the 12mm spacers, I looked at Chris's photos when deciding on whether to go 12mm or 15mm, there's some cracking photos there.
            I've just whacked some 12mm spacers on today, looks a bit wider than it should with only 24mm increase.
            Had a little test drive to make sure the wheels weren't going to fall off. It feels pretty good, might even be a bit better in the corner than before?
            Do spacers improve the handling?, sure feels good:smt055
              The slightly wider track will give it better stability when fronts are done, i.e turn in
                spacers
                running 15mm H&R's all round with stock suspension. Thought mine looked good til i saw the white wrapped csl @ cambourne on the 22nd October. Rear csl mags on the front, absolute dogs b******s!!:thumbs:
                  What about with all 4 done, any difference?
                    Generally a wider track will give you better cornering stability at both ends, but t really so noticeable on the road, But the front is more important due to the natural understeer of the car
                      Shimmy, would you recommend them if so what type and part number. :thumbs:
                        I just bought 4 x 12mm Eibach and extended bolts and eventually extended locking bolts. No idea on part numbers but obviously 5x120mm pattern.
                          I have these
                          http://forums.m3cutters.co.uk/showthread.php?t=26251
                          All good so far up to 150 mph :thumbs:
                            As shim said generally yes, but only really noticeable on track, I was running 15mm all round, on clubsport KW suspension.
                            Black anodised KW spacers ... very nice looking as they don't go all tarnished over time
                            :whistle:
                              Originally posted by bryce View Post
                              Think Im on 10mm's all round Shim
                              +1
                                I have these
                                x2 although the locking nuts supplied are tarnishing a little bit already. Only been on a couple of months.
