Differential Oil - Insp II
    Having had my Insp II just done should my differential oil have been changed. I understand from reading on this site that a change was made to the differential oil used on the service schedule.
    Does anyone have the 'part' number for the new oil so I can check my statement.
    Pip
    Matt :whistle:
    its in the tech section somewhere
      Don't think it's changed in insp 2
      Even new diffs are supplied with the original diff oil and not changed unless you have issues
        I wouldnt worry:thumbs:
          Service book says,change oil in rear axle final drive inspection 2.Mind you, it also says change oil in manual gear box and they dont do that.
            Mine got done during it's insp II.
            Mechanic commented that it was really clean considering the state of the diff :bigcry: :bigcry: :bigcry:
              Don't think it's changed in insp 2.
              As Bounce says it is in the list of things done on an Insp II.
              I take it from the responses that most have not had the new differential oil put in then. I am not sure if I feel more annoyed or placated by these responses.
              Pip
                Pip
                If they change the oil at Insp2 they won't put the new oil type in. They only put new type in as a response to the diff noise issue
                  I had my Inspection II done during the summer and I had the new type diff oil put in. I hadn't made any specific complaint about the diff or otherwise.
                  The part number is 83.22.2.282.583
                  They also put in gearbox oil so maybe my dealer just does it by the book.
                    Diff and gear oil should be replaced on inspection 2 . Modded oil only fitted if noise from diff or customer request ( may put quoted price up a bit if modded oil fitted ) . Hope this helps
                      Thank you for further clarification Giraffe. Actually after speaking to the dealership again to get their bent they said the same ie. that it would only be changed if there was a problem with the existing stuff.
                      I have yet to confirm whether they even changed the differential oil. Let's hope so.
                      Pip
                        I would hope so as price quoted would have included it .
                        They should have a service sheet with tick boxs shows whats done . Hope this helps :thumbs:
