Oil level / top up?
    Oil level / top up?
    Just wondering what the ideal oil level reading is?
    My on board computer was showing 1.0l before my inspection 2 service just recently and after 0.8l ?
    Also what oil do you guys use, wanted to get a ltr top up :thumbs:
    I wouldn't bother topping it up on 0.8 and you don't want it to go over 1.1.There is only the one oil to use really Castrol Edge 10w 60 don't use Edge sport.
      .7 or .8 is fine.
      Never over fill
        Mine is at 1.1 on the dash after its oil service and just on the max on the hard to get too dip stick :hahaha:
        The mechanic got it spot on the max but like other said its better in the .5 to .9 on the dash unless you check the dip stick but you have to take out half the airbox to get to it i posted a video how to do it :thumbs:
          Thanks guys
            I run mine at 1.1 on the track. :thumbs:
              Am i checking mine correctly? when the cars running I just press button on the end of the stalk & it goes through trip / mpg etc then oil level?:119:
                Yep thats all you have to do :-D
                  As long as you have driven it far enough. Too many short journeys gives you ----- when you try to take a reading.
                    You are joking?
                    Never had mine above 0.8 even when going on track.
                      Better to have a little over whilst pulling high G on track.
                        You also get ----- after a day at the track :whistle:
                          It says in the handbook that the ---- lines appear in the display on track, only if you drive like a pussy:gayfight:
                            I cannot find that in my handbook, are the handbooks different for SG and SB ones :whistle:
                              Its written in Braille, they thought it might upset too many:finga:
