Binding front brake
    Binding front brake
    My CSL has started suffering from a binding front calliper, but only when warmed up it seems (no excessive braking or hard driving triggering it off). Is this a common issue & one that will be covered under warranty?
    I am fairly sure it is covered under warranty but cannot be bothered to research this for sure. I do not think that there have been that many instances. Not posted on here at least. However I do recall that some that have had this issue have only had one caliper and disc replaced. In an ideal world both should be replaced for perfect symmetry.
    Pip
      Right I bothered my arse in the end:
      Hi guys just a quick check. The new car is going in tommorrow to try and persuade the dealer that they should be giving me a new Backbox as the clamping brack is cracked and giving a slight rattle when cold and Iv'e also noticed the rear seems to be moving around a little so will be checking out the rtab at the same time. The
      Getting both discs replaced seems a bit hit and miss.
      Pip
        You could replace discs and pads but if the caliper is shoot it will bugger the new ones. I would get into BMW and check calipers first. Gd luck
          Had one caliper seize - covered under warranty.
          Tried to flog me new discs (pr) but had only just had some fitted !
          They backed off and just did the caliper.
          (for avoidance of doubt, this was NOT Elms)
