Side Moulding clips
    Side Moulding clips
    Looking for some side moulding clips and have found them online. Now it looks like there are more than one type fitted to the car.
    Does anyone know how much of each type is required?
    Cheers.
    Links.
    Paul, my memory tells me that there's only one type used for the door and it's 9 or 10 on each door moulding. The rear 1/4 has 3 from memory and the front also 3. I believe it is the front guard that has the different clip.
    I have spare clips at home, will take some photos when I get home (and hopefully a part number also)
    Here's the TIS:
    Edit:
    Here you go:
      Spot on Tom thanks :beer:
      Best go order some up.
        Probably a tad late but i had a similar issue a couple of years back:
        A bit of a boring one but one that others may find useful! A few weeks back my passenger side door trim protector strip started to separate away from the door. I removed it to see what the cause was and it was apparent that several of the plastic clips that hold it in place had broken. So, i went to my local Stealers and
        :-D
          Not at all Rob,
          Tried to order from BMWminiparts and it took a hissy fit so just called the local stealers.
          They list 3 different types so need to see the clip. Your post confirms Toms pic so i can pop in there and choose the correct ones :thumbs:
