Won't start!
Yes, good call:thumbs:
The nice repair man checked the battery with a multimeter whilst the engine was running and explained that the reading could suggest what was wrong:
Less than 13.something volts means the alternator has gone (not enough charge getting into the battery).
Fluctuating between 13.something and 14.2v (I think), the alternator is ok but the battery is not holding the charge (as in my case).
Over 14.2v both ok.
He explained that the engine needed at least 14.2v to start, any less and nothing would happen.
I'm sure someone in the know will correct me if this is a load of bollocks but it might help someone with a similar problem!
He is not very clever then, as a car sat there will not have 14.2v in the battery. Either you misheard him or typo.Originally posted by Jonnymaz View PostYes, good call:thumbs:
Over 14.2v both ok.
He said something about 14.2v being the magic number, although he wasn't particularly clear. Perhaps he was referring to the output of the alternator?Originally posted by lawsy View PostHe is not very clever then, as a car sat there will not have 14.2v in the battery. Either you misheard him or typo.
I was more interested in finding out how to fix it than listening to the science behind it!
I've had exactly the same problem on two occassions. I have a fresh battery since November, the lights are working fine, but it refused to start.
First time I push-started the car, started fine for about a month, until yesterday, same thing.
The car is booked for a clutch replacement next week, I'll have the starting problem checked as well, I'll let you know what it turned out to be.
Hi Pip,Originally posted by Pip1968 View PostSurely then it must be the alternator. With the new battery not being fully charged it probably just held out for the two/three months since it was replaced.
It is a commonly replaced item on the CSL and a warranty item I believe.
Pip
To be honest, I don't think that's the case. When I push started it, it worked fine for two months, which should indicate the alternator is charging the battery? Also now, the lights and everything work perfectly, which should indicate the battery is in good nick (multimeter check confirms this). It seems like an electrical issue, strangely happening two times after I'd washed the car, maybe something to do with water getting where it shouldn't get?
The answer must be don't wash it :whistle: Would be nice to find the problem though.Originally posted by Porker View PostHi Pip,
