Clutch slips - possible reasons?
    Originally posted by Porker View Post
    I have no idea to be honest, the garage said it was considerably cheaper than a clutch, so I assume they've only ordered the accumulator. Will check and let you know when I collect the car.
    Still not sure if that's indeed the fix, they should work on it tomorrow.
    Apparently they've already worked on it today, with the new pump, it apparently shifts OK on some occasions, but then it slipped three shifts in a row. Not entirely solved with the new pump.
    Next up, sleeve?
      it will be wear on the shaft the release bearing travels along i have had 2 replaced :whistle:
        Does anyone have a part no of this "sleeve"? I have no idea what it is, to be honest.
          Item no 1 on this picture
            Thanks man!
              Interesting thread.
              My clutch operation isn't quite perfect but I've always had the feeling the clutch itself isn't a problem.
              could somebody supply the actuator part number - I couldn't see on realoem what this part is (unless you mean the slave cylinder?)
              if it's something easy/external fitting I might make a preemptive strike on a decent oil change and actuator before getting in to the more expensive stuff.
                Got news from the workshop, apparently the suggested sleeve is indeed in need of replacement, as well as part nr. 3 in this picture.
                I hope with this, the culprit has been found. Meanwhile they're also working on the subframe and changing all necessary rubbers, it'll be as good as new when it returns to the Nordschleife this week-end!
                  I'm have similar issues with my clutch & need to get them sorted.
                  So your getting replaced:
                  Item No.1 Guide Bush
                  Item No.3 Clutch Release Bearing
                  :thumbs::thumbs:
                    Yep this will solve ur issue!
                      This is a logical answer, since the symptoms are the same as a worn CRB, but most gearboxes these days are self adjusting and it would need to be pretty knackered?
                      which then also doesn't makes sense why the low milers like the ultra low milers which were recently sold have the "slurr" slip issue. unless of course those either had their clocks turned back or they were stopped in 9k miles of traffic in gear (not hard to do in London mind haha)
                      or what you guys think?
                        Mine has actually covered quite a lot of miles in heavy traffic last year, I was also thinking that might have accelerated the issue...
                        Looking forward to crisp shifts again! :thumbs:
                          :thumbs::thumbs:
                          @Mkoop, that's correct!
                            Got the car back, and imo, the issue hasn't been solved 100%. It's better at low to med revs during full throttle upshifts, but the revs still stick when upshifting at higher revs.
                            Above items 1 & 3 have been changed, as well as a completely different gearbox to verify the difference with my old gearbox, yet the issue persists. Perhaps it's just normal SMG behaviour?
                            Clutch is as new, apparently.
                              That's not good:banghead: You should have crisp changes no matter what rev range your in. Did they swap out the smg ecu when they changed the box? If they did I'm not sure what else there is to change!
                                Slave cylinder is could be on its way out as well....
