Alcon Conversion Front Wheel bell. Where from??
    Need to check my calipers as I'm sure my bleed nipple is pointing upwards!
    As a side note, can only speak highly of Dave at Ears, haven't dealt with him since I had my Evos, top bloke.
      The bleed nipple should be pointing up to let the air out.
      Basically some muppet put my calipers together the wrong way once they were painted... THe smaller of the three (6) pistons should be at the bottom, you can see on mine, it's at the top...
      Nervous wait for parts delivery today....
        An MLR lad was having issues with alcons on his evo, he was wearing pads at crazy angles, and getting pedal issues. I showed him his calipers were on upside down, he changed them and had zero issues after. :supz:
          Hi,
          Quote- THe smaller of the three (6) pistons should be at the bottom, you can see on mine, it's at the top...
          If used as Trailing [e46] but if they had
          been installed on something as Leading then
          they would be the correct configuration.
          BG Developments will make you a pair
          of Proper Brake Belles for around 150/200.
          BG Developments have been synonymous with high performance braking for over 40 years.
          As you already have the original pattern then
          it would be simple to do a later stage, could
          even investigate converting to using PF discs
          and have the new Belles made with a PF
          'PCD' bolt mount, not Alcon.
          Regards,
          The Gorilla.
            Thanks.
            This is very much a "there's no reason this shouldn't work" attempt to get me on the road, rather than a 100% this is a solution.
            If it works then great and i'll liaise with Dave to help ensure the parts are available for whoever else might need them.
              Originally posted by The Gorilla View Post
              Hi,
              Regards,
              The Gorilla.
              But it is an e46 m3, so they are installed incorrectly. :smokin:
              It is e46 m3 Csl we are talking about? :-D
                Thorney csl cup brake kits, brilliant
                  Can't wait to get the car back and have a little look through the invoices to see who installed them...
                    To be fair, I'd be pointing the finger at the people who refurbished the calipers .
                      The calipers were supplied by Thorney in either black or yellow as new.
                        /\ How many nails does he need in his coffin???
                        Fingers crossed everything arrives in time for you johnny
                          Hi,
                          Quote- ''But it is an e46 m3, so they are installed incorrectly.''
                          Oh yes, but the thread seem to suggest that they
                          were from Another source and not on
                          this Car originally ?
                          So Primate was thinking outside the
                          box, as it seems odd that you put something
                          back togther in a different configuration
                          than when you took it apart.
                          More so when it involves Brakes !!
                          But given they emerged from the land
                          of the 400 BHP plus CSL's then I guess
                          anything is possible.
                          Out of interest is there a ''Recall'' on these
                          Alcon Disc Belles then ? or are they
                          not of Alcon Origin ? and the original
                          supplier no longer does CSL go faster
                          bits ?
                          Box sellers, just love em.
                          Regards,
                          The Gorilla.
                            Basically, the CSL cup brakes were developed by Thorney Motorsport and Alcon for the CSL cup racing series as i undersand it.
                            They were brand new disks, calipers, bell houses, bobbins etc.
                            The calipers i guess were supplied by Alcon to Thorney or someone else who sprayed them yellow (or black) and put the CSL cup stickers on them.
                            When someone put my calipers back together, they put them together back to front, or upside down.
                            I don't believe there's a recall, i'm not even sure who would issue a recall? Alcon? Thorney?
                            As it stands at the moment, as of half an hour ago, bobbins had turned up, but no bell houses.
                            Barring a miracle, looks like i'm out, but appreciate all Dave has done and George at Technosport, looks like a courier's let us down.
                            If anyone (seriously) is interested in Spa on Sunday, Ring GP circuit on Tuesday and full VLN on Weds, give me a shout. Even got a couple of Eurotunnel bookings (Saturday AM outbound and Thursday return).
                            Fook it, even got a hotel room at Spa Saturday night and potentially a room at the Pistenklause (you know what i mean) on Sunday, Monday and Tuesday. (subject of course to circuit days and DN agreeing that i can swap the names over)
                              Still out for delivery on UPS apparently....
                                fingers crossed for you mate
