my radio keeps turning itself of any ideas
    the radio in the csl keeps turning itself of about every 20/25 minutes ,it also stays on when the ignition is turned off,probely something im missing having only had the car a month , anybody got any ideas
    jp
    It wants you to hear the induction noiseartyman:.
      What radio is it? Standard BMW business?
        agree with the induction noise :thumbs::thumbs:,its a std buisness radio/cd player its on for approx 25minutes the just switches itself off
          Sounds like headunit is just faulty. They can get warm and shut off.
            mine did the same
            bmw changed it under warranty
              it also stays on when the ignition is turned off ,i cant figure that one out at all
              jp
                jp
                The headunit can be switched on without key in ignition as it has a permanent feed.
                Either a wiring issue or faulty unit.
                But thinking about it, I reckon it could have had an aftermarket head unit fitted, and someone may have swapped the permanent and ignition feed around.
                Does the unit turn on automatically with ignition.
                  no you have to turn it on it wont come on just by ignition and you have to turn it of ,i will have to get it out fit my old buisness cassett player and see if it also goes off after 20 minutes
                  jp
                    jp
                    Shit taste in music ???
                      :hahaha::hahaha:
                        It is possibly dry solder joints that may need another dab of solder on the radio unit or something more technical within. I got a replacement unit on my e39 a few years ago as it would not switch off.
                        Pip
                          I had a weird issue where the heater controls just wouldn't turn off - i noticed you mentioned yours won't turn off - for me I just disconnected the battery for a few minutes and it's been fine ever since - might be worth a shot.
                            :hahaha::hahaha::hahaha:
                              jp
                              Remove the headunit and check the permanent and ignition feeds. Usually red and yellow. If they have been swapped, for when installing an aftermarket radio, then this will be the cause. It should be obvious to spot one head unit is out.
                              Does it keep time, and radio stations?
