BBS CH Sizing
    BBS CH Sizing
    I see most people on here with BBS CH running the following setup
    FR; 19x8.5 +35mm
    RR; 19x10 +20mm
    However have just run into this option
    FR; 19x8.5 +20mm
    RR; 19x10 +20mm
    I have standard suspension.
    Why is this not a popular choice? It is the one reccomended on BBS website, and looks more aggressive.
    I found them for sale here
    Discover the latest alloy wheels and tyres online. Shop from over 5000 wheels, 6000 tyres and accessories from Wheelbase Alloys.
    Here we can see them front and rear in 19x8.5 +20mm
    I'm about to order this sizing
    FR; 19x8.5 +20mm
    RR; 19x10 +20mm
    so would appreciate some input from you guys!
      FR; 19x8.5 +20mm
      RR; 19x10 +20mm
      Hi
      I have 19 x 8.5 ET35 and 19 x 10 ET20.
      The ET35 is not really ET35... it's further out.
      I think at ET20 they will stick too much outside.
      The choice is yours.
      Here some pics -> http://clubcsl.com/index.php/m3-csl-images/31-bbs-ch
        FR; 19x8.5 +20mm
        RR; 19x10 +20mm
        Mine are the Black BBS CH:
        Fronts: 19 x 8.5 (ET 20)
        Rears: 19 x 9.5 (ET20) :thumbs:
          Can i see some pics of yours?
          Any mods required to make it fit? Stock suspension?
            I bought them for the trip, a bit of over enthusiasm as I ended up having to cancel, so I don't have them fitted to the car.
            But to answer your question, there should be no modifications required to fit, they should just bolt straight on.:thumbs:
            The CH's you have listed appear to have a rim protector fitted (Check as these are almost £70 each) also bare in mind Centre Caps and Valves
            BBS Valve caps for the CH wheels are odd, the cap has an extended shoulder to cover the valve, £30 for 4
