air box removal
    air box removal
    gents
    can any one nonce me up a quick link how to remove the top part to give it a little clean inside before we go
    cheers
    It real simple.
    1 unclip and lift the wiring harness that runs along the pollen filter housing.the black pipe that sits above yhe housing is just pinch and pull also.
    2 undo the electric plugs left and right of the intake flap.push down on the metal piece then pull back the plugs.
    3 remove the 3x 25 torx bolts that are onto of the filter box.
    4 while holding the wiring harness,at the back up, lift carefully the back of the box then once you have it raised you need to turn it slightly behind the headlight.
    5 you need to hold the thick pipe under the intake scoop and separate the two parts.
    6 lift out the front part and pull your filter out.
    Replace in reverse order making sure the smaller pipe that runs down the chassis leg slots back in place properly.
      Adam is spot on. I saved this and use it for referance.
        And we have Mark to thank for our own video of how to do it
        Hi i shall do a video how to get to the oil dip stick under the air box (http://s260.photobucket.com/albums/ii14/markcsl/?action=view&current=HOWTO.flv) Hope this helps :thumbs:
        Check your oil level with the dipstick whilst you have it in bits.
          great work
          cheers fellas
