radio code
    radio code
    does the radio /cd have to be coded to the car , my csl came with the buisness radio/cassete player , i then bought a buisness radio/cd player out of a damaged csl ,the problem im having it turns itself of after about 30 mins switches back on fine then again after 30/40 mins it turns its self of ,also it dosent switch of when the ignition is turned of
    any help would be welcome
    jp
    I bought a replacement (visually identical) later year Business Radio to get mp3 reading abilities - works fine.
    Sounds like you have a duff one?
      Try 1742
        Try 1742
        :hahaha::hahaha::hahaha: THEY DONT HAVE CODES and are not coded to the car i would think its faulty
          Ok try 4848
          (mark are you trying to spoil my fun)
            Ok try 4848
              Mine is 2329
                Mine is 1234, same as my bank and credit cards. Means I never look stupid either in the shops or when tuning into Radio Disco
                  I had my radio not turning itself off on my e39 M5 and had to get a new radio module. In the M5 the module was in the boot (small box). Again the switching off problem was a known issue in the e39 and was put down to dry solder on a couple of the connectors on the circuit board.
                  There used to be a very knowledgeable member on the old MTorque board ~ RichardP ???
                  Sounds like a new radio module may be in order perhaps try and swap it out with another M3/CSL owner before you go and spend you hard earned cash.
                  ...........0r try 0000, 0001, 0002.............9997, 9998 and 9999 :hahaha:
                  Pip
                    Give 'Giraffe' a shout, the head unit might need to be reset.:thumbs:
