Fender Rolling/Shaving
    About to order some aggressive rims which might require some fender rolling/shaving to be done. Does anyone have any experience with this?
    Who do you recommend? I am in London.
    IIRC, CSL's came with rolled arches as standard.
      Arch Enemy are one of the better ones. Brave man for doing this on a CSL. I wouldn't be doing anything other than rolling them (no shaving bits off) if it were me, unless they're already rolled like said of course.
        correct :smokin:
          Thanks will check them out. I will have to see whats required but 18x9 front and 18x10.5 rear with +20 offset wont be easy.
          Maybe if not shaving then some fender pulling?
            I think glendog has 10.5's on his.. no shaving or bending on hisartyman:
              Will have to see...stock suspension?
                kw clubsport :beer:
                  I've not got a CSL but the rear arches are rolled. I run a 19x10j rear on what I think is +20 offset so similar, no rubbing whatsoever
                  And on my track wheels I run a 18x9J front and the only rubbing is on my brake ducting. So it's not going to be as bad as you think
                    Thanks. Let me see what the arches look like and do some research. I would really like to avoid changing the suspension. Most people fitting this wheel on e46's have 18x10 front and 18x11.5 rear with +20 offset and 2 inch lip front 3.5 inch lip rear and stretched tyres. I'm trying to find a middle ground by reducing the size abit and make it fit on stock suspension with adequate tyre size.
                      Tim Westwood is your man. The big dog will know for sure :thumbs:
                        Please provide contact info!
                          kw clubsport :beer:
                          :smokin:
                          I get very slight rubbing from the front tyres on the wheel arch liners when I shoot through the Foxhole bottom compression at around 140mph or so...
                            I run a 9.5 front & 10 rear et25 with no rubbing issues so you should be fine with a little neg camber.
