Alternator not covered under warranty
    Hi guys,
    My alternator just went yesterday and BMW are stating this will not be covered under warranty as I have an aftermarket audio system (amps, speakers,subwoofer etc) on the car.
    The repair costs are very high (£860) and I've already replaced an alternator on the car with the system on. Anything I can do? They won't accept me to bring a reconditioned unit or anything like that.
    Thanks
    get the alternator from Pelican parts if you cannot find it cheaper in the UK.
    http://www.pelicanparts.com/cgi-bin/...Each%2520%2520
    I checked the part/no above with the realoem and its correct.
    p/n: 12317831436
    I brought a starter from them a few months ago and they are very professional and delivery was prompt and you get to track the thing from start to finish. :thumbs:
    Hope this helps. Well cheaper than 800+.
    P.S. remember to tell them yours is a UK RHD so they can double confirm the correct part is sent.
      here is the realoem link for the alternator:
      Pelican parts has remanufacturered alternators too. $207 USD
        Find a decent dealer who doesn't make up stupid excuses.....:-D
        Alternatively buy an aftermarket alternator and get it fixed at an indie and exchange for your current, should cost about £300
          Thanks Guys. Only issue is that BMW won't fit any aftermarket or non BMW alternators and I have no way to get the car out of the dealership unless it runs. So abit stuck on this one....
            can always push it out of the door and then tow it to the indie. :-Dartyman:
              Have a quick word with 'adem.csl' in Enfield, he'll no doubt be able to sort you out quickly.
                ALTERNATOR could be done in the car park if needed.
                  You see, Shim's can have you sorted in a jiffy. :gayfight:
                    I've got an original BMW alternator, secondhand, working perfectly, to get it out of there if you want it. Over £800 for an alternator swap is criminal!
                      Unfortunately it would take me 4 hours and I'd break every bit of plastic and cross thread very nut.
                        Does SAILORBAZ not have a new BMW unit ?
                          That was a spare Starter Motor and IIRC S.B. managed to get a full refund on it.
                            Doh :banghead:
                              It is if you don't have Warranty (or you do but it gets refused on a technicality) :banghead:
                              ... especially as these units are less than £200 New (remanufactured) from the likes of GSF or EuroCarParts
