Car in for subframe repair at Elms tomorrow , is it worth getting limiter kit fitted ????
Tuner limiter kit
The solid bushes on my E36 introduced a little more noise, as did the front lower arm bushes when I put powerflex ones on it, there we go I said it and experienced it myself without reading it on the internet, that said it was on an E36 so it may well be the case, although a lot of the bushes are similar things do improve as models change.
I'll pop your blue peter badge in the post :gayfight:Originally posted by Equinox View PostThe solid bushes on my E36 introduced a little more noise, as did the front lower arm bushes when I put powerflex ones on it, there we go I said it and experienced it myself without reading it on the internet, that said it was on an E36 so it may well be the case, although a lot of the bushes are similar things do improve as models change.
I went from standard to powerflex on my Csl and noticed zero difference tbh. I then fitted solid spherical bushes and didn't note any extra intrusion
I however never used my Csl daily. But it does give the car a better feel, less vague.
Majority fit aftermarket loud exhausts so a solid rear trailing arm will likely not be noticeable.
Everyone as different though, horses for courses.
