stud conversion
    stud conversion
    im going to be replacing the wheel nutts with 80mm stud conversion kit,
    has any one done this and whats the best way to install them?
    i was thinking just screw them in with some lock tight on the studs but please tell me if im wrong.
    cheers
    cheers
    Glendog did a write up for people who are unsure of how to install them, but basically yes they are loctite in
      2 ways to do it add loctite to the thread and either use the Allen key end to wind & tighten them, or put 2 wheels nuts on the thread and use a socket to wind & tighten them. Just hold the nut closest to the hub with a spanner when undo'ing the wheel nuts. And done
        I fitted my BBS E88 track wheels today to see if there were any issues with widths or arch/suspension clearances, etc. I decided last year that i would change from wheel bolts to wheel studs/nuts for convenience so i fitted these first. It was a straight forward job and involved cleaning the hub threads prior to applying a
          cheers for the input gents,
          the stud converters i have got dont have alan key heads but i have managed to wind them in by putting two nuts on like graham said,
          the studs dont bottom out into the hub though so have just wound them in 10 - 15mm with loctite on them,
          do you think this will be ok ? surly once the nut is done up this will hold it tight wont it ?
            Where did you get them from?
            Don't scrimp on wheel bolt/nuts, I've bought the turner Motorsport ones, not cheap, but they are good and safe.
              they are a bit budget from ebay,
              these are going on my track car (E36) not the cecil or they would be expensive ones, i guess i just dont want them to fall out !
                Get the bulletnose ones with steel nuts as well. Elite D sell them, or CA. £130 a set, but well worth it.
                And in all black if you wanted.
                  +1 :whistle:
                  I use the 90mm version from Turner Motorsport as I also run wheel spacers:
                    Some fucked up logic right there
                      :hahaha::hahaha:
                        You got to live on the edge lawys !
                          Edge of the Chinese threads :whistle::blalalala:
                          To be honest, sell them on cutters and buy some proven ones. :beer:
