Originally posted by shimmy
Radio options
Originally posted by GregorJP View PostI think I'm in the minority here in my response, but then again I do originate from Leicester, where a top-of-the-line Halfords headset and bargain basement subwoofer and amp combo mark you out as a high street hero.
So..
I upgraded my hifi system in the CSL extensively. I wanted a system that didn't require any change to the standard headset or any other part of the interior of the car, but yet delivered a high quality sound notwithstanding the noise in the CSL. I went to these guys to build it: http://www.advanceav.co.uk.
The system consists of two high power amps, a pre-amp equaliser that is plugged into a laptop and tuned for the car using microphones (both static and driving), 4 new replacement speakers, two tweeters and a detachable 10in subwoofer. Dynamat was kept to a minimum when setting up the system, as I didn't want to add too much weight.
There are no visual clues to the system in the interior - only a hidden jack to connect an iPod and a switch underneath the standard headset.
I love the sound of the CSL more than anything, but on a 5 hour trip to the Ring in constant traffic, I quite like listening to music. The system I have isn't perfect, but it doesn't disrupt the interior and was a great replacement.
I put my headphones on :whistle:
So..
No mate, I couldn't figure out which cable went where!
Though if I knew I'm sure it's easy to tap it in
Do you have yours connected to the OBD port to get the digital gauge function up and running?
Hey mate, yeah it's not a bad unit at all, you'll need a HVAC relocation panel from BMW or Quarry Motors etc. this moves the climate control buttons to where they are on a 'normal' M3, so just above the little storage bin is above the sport button etc.Originally posted by JBird View PostI was thinking of the Dynavin D99 at one point - well either that or a blanking panel! Interested to hear how you find it phoenixcsl, was the satnav and screen OK from a useability point? Any install issues?
Satnav is not bad, I have the option to tether my phone and use Google Maps or use Sygic which i've downloaded as it's a sat nav software that can be run 'offline' i.e. just uses GPS and doesn't need a data connection.
General usability of the unit is easy, Radio is good, CD interface whilst doesn't look amazing does the job, Bluetooth is good, MP3 / USB interfaces are good though looks dated.
Overall it's better than having say the BMW Business CD, with a Parrot and a Sat Nav stuck to the screen, my only gripe is in bright sunlight the screen is a bit iffy.
Attached a pic Mike, my centre trim bit above the unit wasn't on properly when I took it.Originally posted by Mike R View PostGot any pictures?
Dynavin were never on M3 Cutters Chris as far as I know, they did have some forum sponsors with Andrive which was meant to be a better version of what I have got, I've had no trouble updating my firmware on the Dynavin, download the zip file, extract it to the microsd and let the machine do the rest.Originally posted by Chris-CSL View PostI was looking at these units for my car however I heard bad reviews on the Dynavin Units from M3cutters forum mainly around the O/S with upgrades etc. They where a Forum sponsor but I do believe they have now gone.
Got any pictures?Originally posted by phoenixcsl View PostMuch like the others I hardly use my stereo, the car sounds too good for it!
I'm personally not a fan of aftermarket head units in the CSL as look a bit out of place, but I ended up with a Dynavin D99 Android unit, has google maps / navigation, bluetooth etc, and looks fairly OEM.
opening the window and driving is a better sound than the radio :hahaha:Originally posted by Neil M View PostGood idea.
This is the amount of stuff you would need to retrofit.
I'm looking into doing this to my car. I know I need: The monitor, M4 nav computer Tv module Radio module. Now what I'm not clear on is the loom, my car already has the hk system and I think you can buy a satnav retrofit harness but is that all you need?? Something like this http://cgi.ebay.co.uk...
The other link was just for the hands on experience 'how to turn an CSL into an M3'
Obviously most of you only use your cars for short journeys :gayfight:.
Good idea.Originally posted by FMC View PostYeaa, the sound of the engine at high revs is all you need, the radio will probably be a distraction.
Thanks for the ideas, will just leave as is.
thanks
Faisal
thanks
Faisal
I've never turned mine on, as it not a daily I've never found the need with the in-built orchestra under the bonnet, it would only detract from the experience.
However: http://www.m3torque.co.uk/showthread.php?t=1827 :thumbs:
