Does the SMG block shift say from 5-2 by simply holding down the left paddle? Tks
block shift
Erm...not sure about bloke shifting as you would a conventional manual. A double click will bang it up or down two gears. I would go out and try the 5th to 2nd thing but am also intoxicated and the roads are salty!:banghead:
Not because of me might I add!
Not that kind of night in! I blame a lack of posts in the men's room
totally fucked now pall ,will check in torromorrow 😳Originally posted by MarcM View PostErm...not sure about bloke shifting as you would a conventional manual. A double click will bang it up or down two gears. I would go out and try the 5th to 2nd thing but am also intoxicated and the roads are salty!:banghead:
Never tried it, but I doubt it. How is the gearbox to know which gear you want.Originally posted by khooni View Postlol.
meant holding down the left paddle without clicking 3 times to shift to 2nd gear. I'm off to brands today so i'll try it. Merry xmas fellas.
Let us know how you get on. Hope you have fun.
Man, this means just holding down the paddle and the gearbox will select the lowest possible gear to be in (Manual mode)
Anyway, the CSL won't block shift. you have to click 3 times to get from 5th to 2nd in manual mode
also, when in noise test and in neutral, the csl only revs to 6,000 rpm.....
anyway had a good day out. slippery on cups in the morning but getting better by the afternoon when temps got to 7C.
The CSL will rev right round when warm in neutral, limits the revs when cold as its not good to rev them round when cold:bigcry:Originally posted by khooni View PostMan, this means just holding down the paddle and the gearbox will select the lowest possible gear to be in (Manual mode)
