Originally posted by mistergav
Elms Boot Floor Repair
If I were you I'd ask the Scottish dealer to have a look inside all the rear boot cavities with a video inspection scope for any rust eating it's way from inside out, considering the amount of surface rust you have now. :banghead: If any cavity rust is found I would insist on Elms Bedford having to do this job all over again, to a much higher standard.
You must have been very lucky and caught them on a good week BretOriginally posted by Bounce View PostElms Stanstead did my boot floor and did a nice tidy job.
because Gareth @ Elms (Cambridge ) had to finish and repair what they started and broke on mine :banghead:
It's perfect now but only thanks to Gareth & Steve for going out of their way for me :thumbs:
BTW have you had a good, close look at your CSLs boot repair recently ? :whistle:
Got to say Matt mine was also spot on, really nice job and still looks new at just over a year old. I regularly stick it over the pit for inspection (force of habit).
Did Cambridge not send their floor repairs to Bedford? Pretty sure that's what I was told when my process kicked off. Its where I was supposed to be done but they were about 6 months behind so I was re booked at Stanstead.
Elms sent mine to Hitchin. Looked a good job when they had finished. Showed me under the car, inside and the cracked section they had cut out. They also sent me photos. That was just over a year ago. Will get Gareth to check it out when it goes in for it's annual oil change.
They also changed front & rear bushes at the same time. :thumbs:
Did they charge you extra for the bushes? I asked to have mine changed when the subframe was being done, I think they wanted an extra £400 from memory. Luckily when it came to it my bushes had already been up rated with Turner MSport bushes prior to my ownership. I've found Bedford to be superb with everything they have done with my cars. The repair on mine is nearly complete and should be getting it back very soon. Luckily I'm only 10 mins from Bedford and have been able to pop in a few times to see how it's coming along.Originally posted by Trawler View PostElms sent mine to Hitchin. Looked a good job when they had finished. Showed me under the car, inside and the cracked section they had cut out. They also sent me photos. That was just over a year ago. Will get Gareth to check it out when it goes in for it's annual oil change.
Not good with the boot floor from the OP, I'd be surprised if Elms didn't put it right for you.
Cambridge doesn't have a body shop so sends everything to Bedford, I was talking to the DP in Cambridge and that’s what he told me. Mine was ‘repaired’ in Bedford.Originally posted by rstoughy View PostGot to say Matt mine was also spot on, really nice job and still looks new at just over a year old. I regularly stick it over the pit for inspection (force of habit).
BMW in Scotland quoted £4,440.05 to put it right, that includes dropping the running gear, cleaning and resealing the entire boot floor inside and out. I have passed that quote to Bedford and await their comments on Tuesday.
The technical manager for BMW Scotland and Ireland is also coming to look at the sub-standard repair.
Its getting fixed regardless, just interested to see if Elms are going to take ownership....
They only charged me for the parts, which, I thought was a good deal.Originally posted by jupe777 View PostDid they charge you extra for the bushes? I asked to have mine changed when the subframe was being done, I think they wanted an extra £400 from memory. Luckily when it came to it my bushes had already been up rated with Turner MSport bushes prior to my ownership.
Mine too :thumbs:Originally posted by Trawler View PostElms sent mine to Hitchin. Looked a good job when they had finished. Showed me under the car, inside and the cracked section they had cut out. They also sent me photos. That was just over a year ago. Will get Gareth to check it out when it goes in for it's annual oil change.
