CD diffuser removal
    CD diffuser removal
    Does anyone know how to remove the CF diffuser part of the rear bumper?
    I just want to get it off so that I can get to the top pop rivet on the tailpipes to remove it as I have a nice set of replacements I was going to fit :-)
    As far as i know there are a couple of plastic push rivets on the underside of the diffusor and 2 screws in the middle. Remove those and then gently pry the diffusor out, it is then just held by clips.
      Excellent, I shall have a look this evening, it will be a lot simpler to get at the rivets than it was on the Z4 hopefully! I had to spend a while grinding them off with a flexi-drive and a Dremel, the alternative was to remove the bumper!
        This. Don't be scared, it needs a bit of a yank. Move from one side to the other.
          Just a bit careful as it could be clipped in tight.
            Be very scared. Once you have removed the plastic rivits below, there are a series of clips along the top. If it hasn't been off before these will be tighter than a nuns nasty, although they are molded carbon, they can break.
              Might be an idea to squirt a bit of silicone spray unto these top clips before commencing battle
              As Jay said they are proper tight, a complete bugger to shift and can brake :banghead:
                Done, the clips are pretty tight but it came off, not very good photos but here's the new tail pipes...
                2015-06-03 21.33.42 by Darren Teagles, on Flickr
                Easy to swap back now if I don't like them....but I do!
                  Looks good what make are those? :thumbs:
                    I bought them from CA Automotive back in 2011 but they don't do them any longer, these are the ones:
                    Since 2002 the Emnotek team has provided customers with high quality car and truck performance parts and accessories.
                      There is a guy on cutters selling sets for 150.
