Up up and away!
No I had to arrange this by myself. I'm in Aberdeen and Redish are in Bristol. This might look excessive but it's cheaper than a day off work and the associated expenses if I were to drive it down and fly back. It certainly had the neighbour's curtains twitching.
I'll keep you all posted on the Redish experience.
Out of interest what ballpark does that return transportation cost? Let us know if you would recommend the transportation firm that you used. :thumbs:Originally posted by GregorFuk View PostNo I had to arrange this by myself. I'm in Aberdeen and Redish are in Bristol. This might look excessive but it's cheaper than a day off work and the associated expenses if I were to drive it down and fly back. It certainly had the neighbour's curtains twitching.
No, not the full works. I drive the car too much for that.
Plan is to remove the subframe and do the plating. They will then do a paint & protect, and I have asked this to be extended out to the wheel arches rather than limit it to the axel carrier panel. Subframe will be blasted and powdercoated then re-fitted with new subframe and diff carrier bushes. I’m also having the rubber coupling in the propshaft replaced. Anything that either falls of off, or needs cut off, will also be replaced with new OEM (thinking exhaust shields etc).
So no, not the full works. But the important stuff plus a little bit. I see this as both adding value to the car and giving me piece of mind.
Re getting together, yes we should get something sorted. Seems there are more CSL owners in ABZ than I thought. I figured it was just me an Paul. Will have to wait till spring though as mine will be going straight into hibernation once it’s back.
Lol yes there's a few stashed away in the suburbs. I've not seen mine since May this year when I parked it in storage.
Just been too busy with the other one to give the CSL the attention it deserves.
Nigel and John used that company for transportation before so not the 1st time that cars been on that truck.
Yes Paul. I used them on Nigel's recommendation so I have no worries. Car should arrive at Redish today.Originally posted by rstoughy View PostLol yes there's a few stashed away in the suburbs. I've not seen mine since May this year when I parked it in storage.
James and Pete at Redish did a great job with my car.Originally posted by GregorFuk View PostNo, not the full works. I drive the car too much for that.
It's my car in this thread:
I'd loved to have got their full underbody restoration done, but I didn't have the funds to do it at the time (and had a driving holiday coming up as well)
as I know a few lads in track prep'd E46's that would be up for it as well.
