Soft Brake Pedal
    Soft Brake Pedal
    i am plagued by a soft brake pedal problem that I can't solve and want to see if any of you guys can help. The brake pedal is soft and I mean really soft even compared to other e46 m3's or normal BMWs. I have bled the system, changed fluid, bled the system again. I then thought it was a vacuum leak so I had vacuum hoses and brake booster changed. I am still having this problem and it won't go away. Next thing I am going to try is having the master cylinder changed.
    Any one have any clue as to what this problem may be?
    A_Y
    you should be able to get a seal kit for the master cylinder
    If there's no obvious fluid leaking onto the floor then it could be fluid getting back past the master cylinder piston under braking. Not a common fault but worth a look.
      i am plagued by a soft brake pedal problem that I can't solve and want to see if any of you guys can help. The brake pedal is soft and I mean really soft even compared to other e46 m3's or normal BMWs. I have bled the system, changed fluid, bled the system again. I then thought it was a vacuum leak so I had vacuum hoses and brake booster changed. I am still having this problem and it won't go away. Next thing I am going to try is having the master cylinder k
      You need AP brakes :thumbs:
        Originally posted by cslsuperfan View Post
        A_Y
        I have ordered a new master from the dealer today.. let's see if this works...
        next step! i need to get this sorted before getting that!
          Did you bleed the brakes or did BMW ?
            Who's at fault :whistle:
              BMW both using a power bleeder and doing it manually
                I reckon they have done it wrong. You and a mate need to do it and really stamp on the peddle pushing it all through. BMW always make it limp.
                  They have done it correct but not to anyone's liking
                    Can you kindly explain what is the correct way? Thanks!
                      I recently saw on m3forum about a method called the TIS method of bleeding the brake and abs/dsc system. Do you guys know anything about this method that you can share? Thanks!
                        Im glad to say that the brake issue has been solved after replacing the master cylinder! Cesil all healthy now!
                          hi all,,my first post on here an its off topic but i can't start a new thread yet :-(,,I've just had an inspection 2 on my csl and everything was marvelous apart from,,and i quote "a slight groan from the dif",just wondered if anyone else has had this and what work is involved
                          thanks in advance
