Get anything that's large and metal powder coated!!
Redish motorsport restoration
Redish will do whatever you want and tailor things to your budget.Originally posted by Brendanmck View PostThat's the problem how much do you spend.im sure if we all look under our cars we would find plenty we'd like to replace. If you go all out and get the works done your car becomes a garage queen because your afraid to undo all the good work. And if you do the minimum you'll probably regret not doing more. If I decide it's the fix for me bearing in mind it's a ferry ride over the pond. Il be looking the restoration done may well be cheaper in the long run and a great selling on point.
I had an extended rear end refresh. So all the usual plating and foam injection stuff done but in addition I had all corrosion on the rear half of the car treated and then the whole rear of the underside painted and undersealed right out to the wheel arches. I had the subframe powder coated and new subframe and diff carrier bushes and fitted. I also had new rear brake lines fitted.
It does look like a new car underneath but it hasn’t stopped me using it. If anything it’s given me the confidence to use it more as I know the car isn’t pulling itself apart.
I did’t have the front half of the car restored because to be honest, it was’t that bad. There’s a lot more shielding up front and the heat from the engine / gearbox means things don’t sit damp for long.
The work you had done is what I intend having done and you're right I guess knowing your car is sound underneath would give you plenty of confidence to drive your car more. Do you mind me asking how much it cost to have all of that work done ? You can pm me if you prepare .Originally posted by GregorFuk View PostRedish will do whatever you want and tailor things to your budget.
I can't remember the exact breakdown but I could fish out the invoice. It was a little over £4k. But that included a compression test, which in turn requires a valve adjustment beforehand to make sure everything is sealing properly before running the test. I guess you could knock ~£600 off the price if you omitted that. I can PM you the full details later tonight.Originally posted by Brendanmck View PostThe work you had done is what I intend having done and you're right I guess knowing your car is sound underneath would give you plenty of confidence to drive your car more. Do you mind me asking how much it cost to have all of that work done ? You can pm me if you prepare .
Thanks Ben, had them checked and apparently they are in good condition.Originally posted by cslsuperfan View PostI believe brake lines run underneath subframe so get your engineer to check/replace as it will be removed from the car.
Had them do that, subframe bushings are replaced with poly ones. Diff are still as good as new (got a new diff 2 years ago). ThanksOriginally posted by billyboysm3 View PostBartletts changed my brake lines at the same time.
change all subframe bushes, diff and rtab all at the same time.
Then that will last another 10 years.
Originally posted by Marv968 View PostGet anything that's large and metal powder coated!!
I've thought about getting the rear axle powder coated too, but since she has spent all its life on the gran canarian roads it would be a bit overkill. imho.
Thanks for your opinions guys, picking her up on thursday. Can't wait to find out how she drives :smt055
That would be great . ThanksOriginally posted by GregorFuk View PostI can't remember the exact breakdown but I could fish out the invoice. It was a little over £4k. But that included a compression test, which in turn requires a valve adjustment beforehand to make sure everything is sealing properly before running the test. I guess you could knock ~£600 off the price if you omitted that. I can PM you the full details later tonight.
