Noise levels
    Noise levels
    Looking at the noise level allowed for evenings at Donington and it is 98db.
    Not over sure I'd get by on that with running a SS LWR back box and non - res SS centre pipe.
    Anyone running similar and have any idea?
    Secondly, could I just have a run up to Donington when there is a track day there and I'm home and blag a noise test? Or could I only get a test if I've coughed up for the day?
    Not sure how it all works.
    with SS LWR back box, SS Res Centre, a/m cats and oem cat i have never tripoped any noise meters in the UK inluding BEdford, Donny, Oulton, Rocky, Silverstone, Castle Combe, Snetterton.
    Only place i tripped the meters was at Zolder, anbd that was after Curly in his Skoda shoppper tripped it before me so i ran aroudn at full revs in 3rd just to piss them off.
    CSL at Donny is fine.
      That 98db is also drive by.
      I had that set up with supersprint cats and didn't trip it.
        Put it this way. Bedford is very strict with a drive by of 88db ish so donny you could probably get away with a gruppe m.
          I have race box and resonated centre section. Static at 93
          Non resonated is louder?
            yep
            non res lets a couple more ponies through.
              i recall Woppum once got black flagged at Bedford with full SS and cats, non res. HE had done it maybe 5-10 times and one day he went above the BEdford limit
                Originally posted by cslsuperfan View Post
                yep
                I hate worrying about track noise limits though. The exhaust mod for me was never about hp, it was about weight loss. I was perfectly happy with the stock sounding exhaust
                  I have the full Supersprint system from the headers back, with the light-weight race back box and it is 106dB static :bigcry::whistle:. So beware, as it would seem adding the Sports Cats gives a big jump in noise.
                  When I last went to Bedford, they just laughed and wouldn't even let me try a drive by .
                    Cats add 3 db, non res adds 3 db then the rest is your back box.
                      Mike
                      Your SS box is fucked, no way is it anywhere near that noise level static even with cats, as ive said before non-res can push the limits at Bedford o a full system but 9/10 times it will be ok
                        Mike
                        Agreed I have no problem at Bedford
                          I have the FULL system tip to tail with LW Race/100 cell SS cats/ non-res centre and SS headers and I think its on or about 102db.
                            You realise all this trick exhaust kit makes you neither faster nor a better driver ?
                            :smokin:
                              :smokin:
                              You're so right Ian.
