Originally posted by shimmy
Tyre pressure monitors
Mine has done it since first SPA date, never bothered with it again just ignore it :thumbs:
Yep, you will need to be particularly unmanly and read the instructions
+1. Have seen problems in the past with the system not being reset correctly, causing false warnings.Originally posted by Mike R View PostYou have to do the reset properly (as per the manual), just pressing the button doesn't do the reset, you have to go through the process with ignition etc?
Mines a bit temperamental,wheel spacers shouldn't make any difference,you just have to stick with it and keep resetting it till it stops,have a look in the hand book and will tell you the procedure
Hi Chaps
Iv recently been running a square set up on my car for a few month and thought while the OEM wheels were of I thought it would be a good time to give them a full re-furb from lepsons "who did a fantastic job by the way"
I have just got round to putting them on this week and after about 15miles I'm getting the flat tyre tell tell light come up on the dash, I have tried to reset it a few times but It keeps coming back!!
I have also fitted wheel spacers to the car when putting the wheels on and I don't know if this will have any affect on anything?
all the pressures are ok
any help would be appreciated
cheersTags: None
