BBS e88
    BBS e88
    I fitted my BBS E88 track wheels today to see if there were any issues with widths or arch/suspension clearances, etc.
    I decided last year that i would change from wheel bolts to wheel studs/nuts for convenience so i fitted these first. It was a straight forward job and involved cleaning the hub threads prior to applying a drop of Loctite 262 high strength threadlocker and torque tightening the studs to 16 ft lbs.
    The 10.5 x 18J rears went on without spacers and fitted nicely with a little clearance from the wheel arch and without any issues with suspension.
    The 9.5 x 18J fronts had to have 12mm spacers fitted to fit ok and even so the inner edge of the rim is at most 5mm away from my KW Clubsport spring/strut upright... The top outer edge of the tyre looks like it would come into contact with the arch but this is partly down to only having around -2.2 degrees camber set on the fronts vice the -3.2 that i use on track.
    I took it for a gentle test drive and am relieved to report that all seemed well although i was careful to not make the suspension compress at any point! I'm not overly keen on the wider front 18's 'blocky' appearance either but the drive felt so different to standard wheels and was almost go-kart like despite the Cups scrabbling for grip in the cold temperatures.
    It will be interesting to see what this set-up is like on track! Looking forward to Donny on the 18th :whistle:
    :smokin:
    looking good personally prefer original csl wheels but for track option very good.liking the nice clean arches too :thumbs:
      Looking good!!!!
        Love them, prefer the gold centres though.
        10mm spacer on the front would give you a little more room on the outside?
          i'm doing donington on the 18th too. i'll try not to get in your way
            Wheels look :drool: liking then a lot.
            Ando.
              Looking good Rob :thumbs:
                Looks good!:thumbs:
                What offset do they work out to be? I say they will rub at the point where the wing meets the bumper.
                  Looking good Shortstuff :thumbs:
                    :hahaha:
                    Nice Rob .. Gold centres needed also
                    My cups are in storage at ze ring :-(
                      Looks awesome Rob, although I think pink centres would set them off :thumbs:
                        Look cool, what offset at the front?
                          Lookin good rob
                          It will look awesome on track
                          You will notice a big difference on turn in,
                          How are the Tyres I got you?
                            I was thinking that - i need to dial in the extra camber on the fronts to.
                            :hahaha: I drive slow and steady :whistle:
                            I think on a SB car that would look great but i prefer all silver on the SG :smokin:
                            :birdman:
                            Front: ET41
                            Rear: ET28
                            Lookin good rob
                            I noticed a big difference on road yesterday on a short test drive!
                            Your rear tyres were cold and hard yesterday - spinning away merrily :hahaha:
                              They're looking v.smart Rob! :thumbs:
                              You running a 285 on the rear there?
