Hey there Mates!
  • dafoe
    Csl cams
    Hey Fellas!
    The M3 is running strong as ever! The headers are good, the Evolve Airbox is better, but what I am need of now, without breaking the bank, is a set of CSL cams!
    If ANYONE can help a friend from across the pond acquire a set of good CSL cams, I would be MOST Grateful!!
    Hope all is well with everyone!
    Dave
  • AlexGTT
    It'll make next to no difference the oil temps. There are slight benefits as outlined by The Gorilla. I have a fair amount of experience with ceramic coated exhausts as we use them a lot on the cars we work on but that is only because of the close proximity of carburettors/fuel lines, etc. They help a lot with fuel percolation issues. The issue is fairly well illustrated in the following picture, although this is before we coated the manifold.
    I'd be more inclined to used ceramic coating on turbochaged road cars but less so on N/A.
  • shane@mbtech
    Originally posted by The Gorilla View Post
    Hi,
    Quote-
    ''What are your thoughts on "coated" exhausts. And any science behind it G man?
    We had a discussion about this the other day in work.
    Pro';s and cons.
    I think it was Super Sprint that played around with
    'Coated' and 'Ceramics' on Manifolds and Exhausts
    a while ago.
    The issue many forget, is that most F1 Cars,
    Race Cars and Bikes in the higher echelon of
    Motorsport are running something like
    0.8mm side wall thickness Inconnel Headers,
    exhausts pipes etc.
    So Heat is a big problem, more so where
    it can transfer and cause heat soak to
    materials like Carbon, plastics, nylons etc
    all frequetly used in modern day race cars.
    Hence the need to contain the exhaust
    heat as much and where ever possible.
    On a street/track car, then under bonnet
    temps will be down some, but as to if
    this makes a little more power is just a
    subjective view, pending where you sit.
    If I was selling Coatings, then of course it
    would assist in making more power,
    better exhaust scavange, lower oil
    temps, and so on.
    As I am not, then my personal view is
    that its just another product being used
    in Motorsport under totally different
    conditions and circumstances, which is now
    offered and sold to the public at large on
    the basis F1 / Motorsport has it, and the
    leemings as always will follow.
    A drop in ambinet under bonnet temp by say
    20 degrees will do nothing at all to your
    oil temp when static, even less at full chat.
    Regards,
    The Gorilla
    Have you datalogged this, or is it just your "opinion".
    At times, i think there are benefits, then I think there are none.
    With regards to your quote re the ambient temps.
    Tesco say that every little helps.
  • Bounce
    Dont be a cooont ! I would burn myself !!:hahaha:
    :hahaha::hahaha:
  • The Gorilla
    Hi,
    Quote-
    Pro';s and cons.
    a while ago.
    exhausts pipes etc.
    temps, and so on.
    Regards,
    The Gorilla
  • DuncanR
    have you ever felt how hot the manifold gets!
  • shimmy
    use your head, best keep vital organs clear :smokin:
  • DuncanR
  • shimmy
    With my limited experience and Knowledge of such matters, and applying the KISS rule, I would imagine that the oil cooler path is more cost effective and has a far more direct impact on dropping the oil temp, wouldnt you ? ....well wouldnt you ? :smt102
  • CraigMillwardCroft
    :hahaha::hahaha::hahaha:
  • DuncanR
    What is the KISS rule ?? :thumbs:
    Keep it simple stupid
  • DuncanR
    I wondered if i could avoid a bigger oil cooler by running coated manifold but wasnt sure on the knock on effects:smokin:
  • shimmy
    Pro';s and cons.
  • shane@mbtech
    Hi,
    Quote-
    '' there is a reason why f1 teams use zircotec tho I would have thought?
    Haven't you just listed one of many factors?
    anything that will stop a gas cooling down, and therefore slowing down will help I would imagine?
    For sure Zircotec will bring down the under bonnet temp,
    which means the gases in the exhaust stay hotter.
    Have a look at some 'coated' exhaust manifolds after
    say 10,000 miles , which F1 and Race cars do not
    exceed to without rebuilds etc.
    Scavenge is very complex as already stated, and
    raising the exhaust gas temp does not mean that
    scavange is improved, more so when running
    Cats, which F1 Car's etc do not.
    Regards,
    The Gorilla.
    Pro';s and cons.
