Carbon Rear Seat rest
    I have to clean the mold now and then try and make one the cost will depend on the amount of carbon and time involved :whistle:
      Looking good Mark!!! That mould ain't half bad. Bit of wet and dry from 1200 to 2000 should tidy it up real nice!! Some of the edges look a little suspect, but overall not bad. I think you'd pull about 4 or 5 copies from this before a repair to the mould.
        Got my dash trim yesterday just got to fit it to the car Cheers Mark:thumbs:
          The rough edges are above the seat mould but yes they will be tided up with gel coat Tom
          And yes it will be rubbed down with wet and dry :supz:
          I was thinking 3 layers of 200g carbon should be strong enough also if it need more i can add it inside the part :-D
            They are easy to install just be careful with the radio and the one above the glove box where they meet as they are a close fit :-D
              Rear seat part was in the mould :-D
                This is what it looks like out the mould :bigcry::bigcry::bigcry:
                  Back to the drawing board it did not want to come out the mould the recess is the tough part to do as it wants to lock its self to the mould its time to try something else :whistle:
                    Use compressed air to blow in between the mould and item to separate - if you've waxed the part properly and put enough PVC release agent it should just come apart.
                    It's usually stuck due to surface tension and friction - compressed air will sort that out.
                    You should still work your magic and see if you can repair that broken one Mark :-D
