Nice work...
my M3 CSL
I have noticed with AP's on front back brakes are over heating and wearing down quicker and that was even in the wet.Originally posted by mattCSLnut View PostWhat you say makes sense :thumbs: and it seems to work well on the current generation of M cars but do keep an eye on your rear pad wear as when I did my Porsche BREMBO conversion starting with only the fronts at first, I noticed the wear rate of my rear pads was 2-3 sets of rear pads for every one set of the fronts. This is why soon after fitting the fronts I added the rear BREMBOs :beer: Since then the pad wear rate has evened out to a ration of 1:1, front to rear.
What Matt says makes sense because the rear pad surface is smaller therefore more material will be used.
The AP setup has rear discs with the same dimensions to the OEM discs (i was running my OEM discs).
I haven't seen a problem now and with rear pads at 1/4 of brembo rear pads, i will leave it like this for now.
Great lap. May I ask which telemetry setup is that ?Originally posted by alexk View PostI had a great day yesterday at Monza.
I did 4 30-minute sessions
Here is a video of my fastest lap of the day :thumbs:
https://www.youtube.com/watch?v=S2AM7tK1Zlo
shimmy > thanks mate. I can go even faster but the pads (currently the road-friendly pads) didn't give me so much confidence. Nevertheless in 3 braking points I hit the brakes at 100m :thumbs:
clubber > It is the RaceChrono Pro. I am using it since years with a bluetooth 10Hz receiver (Qstarz BT818X).
I was condidering to get the racelogic 20Hz BT unit but the position accuracy is worse than the one I currently have.
I just realized it is for androids. I use an iPhone 6 with my Harry's Lap timer app, although having difficulty overlaying OBD info. Which obd reader do you use ?Originally posted by alexk View Postclubber > It is the RaceChrono Pro. I am using it since years with a bluetooth 10Hz receiver (Qstarz BT818X).
I use obd key http://www.obdkey.com/Originally posted by Clubber View PostI just realized it is for androids. I use an iPhone 6 with my Harry's Lap timer app, although having difficulty overlaying OBD info. Which obd reader do you use ?
