my M3 CSL
    why not recaro spg or spa?
      Spa 2.5Kgs.....yummy
        I am considering the SPG too.
        But I need to see them live and test them.
        A bit difficult this
          25.04.2015
          A part which is a bit unnecessary and adds weight is the secondary air pump.
          This blows air in the exhaust manifold to make the emissions look better.
          It's common practice in motorbikes to remove this air pump.
          BMW is offering a block of plate for the cylinderhead of the S54 to close the hole once you remove it.
          Here it is.
          Only 16g of weight
          Here the pump removed.
          1448g
          And the pipe with the valve.
          252g
          So here we have 1.7kg of weight removed with a cost of 25 EUR.
          Unlike my Yamaha R1, the CSL is supposed to have a check engine light because I removed this pump.
          The engine light didn't come on yet.
          I will explain how we deal with this by reprogramming the ECU
            Some parts seem to be that heavy concrete cracked :whistle:
              for me the most suprising weight is the original exhaust backbox, what were they thinking to put this on a CSL? its like moving a rock. its damn heavy.
                Here it is.
                Only 16g of weight
                :thumbs: :thumbs:
                Any light yet Alex?
                  +1 :bigcry:
                    The CSL concept car had a titanium full exhaust (headers all the way to the backbox) and the backbox had carbon exhaust tips.
                    Where do you think Akrapovic got the idea from ? :thumbs:
                    :thumbs: :thumbs:
                    Any light yet Alex?
                    No light yet Rob.
                    As soon as it appears, I will explain what I am doing to resolve this.
                      ... a 25 kg rock :banghead:
                        Supersprint SS race lightweight should have been OEM !
                          :thumbs: many of us have made it OEM :supz: retrospectively
                            No light yet Rob.
                            Thanks mate :thumbs:
                            :supz: :supz: :supz:
                              Check engine light - secondary air pump
                              After a couple of days the engine light turned on. Remember I have removed the secondary air pump.
                              The Diagnostic Trouble Code (aka DTC) is the AA (0xAA) from the DME.
                              The credit for the below belongs to the great work done by a few guys in the m3forum.net . I have helped them more than a year ago when I gave them a full export of the CSL map (I have an unrestricted CSL).
                              Here is the forum thread with all the info -> http://www.m3forum.net/m3forum/showthread.php?t=423771
                              I have read all pages and NO I don't have so much free time.
                              1. First I take a partial export of the CSL ECU code which is 64kB (aka kilobytes = 64 x 1024 bytes = 65536 bytes). The full export of the CSL ECU code is 1024 kB = 1MB.
                              2. I need to find the version of the map.
                              You go to the byte offset (or address) 0xBFB8 and see the last 4 digits.
                              2113 2500 0301 PD71. (there is also 0401 version)
                              This means, the secondary air pump configuration is in byte offset 0xC100.
                              3. I go to offset 0xC100.
                              The stock string is 01 FF 04 B0 5F AA.
                              01 -> K_SLS_OBD = switch on / off
                              5F -> K_SLS_UB_MIN = default is 9.5V
                              AA -> K_SLS_UB_MAX = default is 17.0V
                              I switch the 01 to 00 to completely disable the pump, the 5F to B9 (18.5V) and the AA to B9 (18.5V). With the high values the pump will never be enabled.
                              The new string is 00 FF 04 B0 B9 B9
                              4. Now I need to disable the DTC checking. This will mean there will be no check engine lights from now on. The ECU will just ignore whether the pump exists, works etc.
                              The 301 version of the CSL map that I have has the 0xAA DTC code in offset 0xF3BE.
                              The OEM string is -> AA 01 01 01 01 01 01 00 01 02 03 28 27 FF
                              There are a few methods to disable this.
                              I will zero out the last 2 digits before the FF digits so the string becomes.
                              AA 01 01 01 01 01 01 00 01 02 03 28 00 FF
                              5. At this point I decided that I need to finally enable the sport button memory. It's always annoying having to press the sport button. I always use sport mode.
                              The CSL map has this in offset 0x8026.
                              You find the string -> 01 02 1E 14 FF FF 03. Change 03 to 04.
                              The updated string -> 01 02 1E 14 FF FF 04
                              6. Now I need to calculate and update the checksum of the ECU map file, otherwise the ECU will not boot and the car will not work.
                              I used the MSS54CheckSumCorrectionTool.exe program that works like a dream.
                              You can download this here https://dl.dropbox.com/s/ym8amldnz79...nTool.exe?dl=1
                              7. Then I use again the BMWFlash.exe software to write the map to the car.
                              http://bimmersoftware.com/bmwflash
                              8. Start the car and enjoy
                              In order to do the above someone needs a USB to OBD cable.
                              I have this one.
                              Here the code of the map.
                              Here when I was writing the map back to the car.
                              You need a good laptop with charger and also the car to be in a battery charger.
                              You don't want this to abort :hahaha:
                              Last point.
                              If someone needs help with your maps to enable/disable any of the features found by the m3forum group, I could help you.
                              However you would need to buy your own cable and then read/write the maps on your own.
                                Yesterday I did a time attack event in the French track Anneau du Rhin.
                                Although I improved my laptime by 2 secs I was put in the category of RWD Pro (open to all modifications... so the other cars were race cars) and only managed to be 4th.
                                My best laptime was 1:24.8 and did many many laps at 1:25.
                                I did 120+ laps in total.
                                As I have different front calipers, my car was considered a race car.
                                Funnily enough, in the street category there were 3 E36 M3s with stripped out interior, rollcage, seats and the list goes on.... but had OEM brake calipers.
                                It was a hot day (35C) and there was a lot of sliding and limited traction.
                                Here is a video.
                                It was impossible to go any faster.
