HAHA I see your steering rack and raise you a parts list.
Complete breakdown on the current setup of the car in regards to parts.
**Please note: these are prices as listed on the website as of 2/2013 – not what I paid for them** I have been building this car going on 11 years now.https://docs.google.com/spreadsheet/...EE&usp=sharing
CSL Air Intake
11617833496 --- AIR COLLECTOR
11617831740 --- BRACKET
7119902973 ---- HEX BOLT WITH WASHER
7119900398 ---- HEX NUT --- X2
11617831745 --- MUFFLER CLAMP --- X6
11617833497 --- UNFILTERED AIR HOUSING
11617833648 --- INTAKE
7129952137 ---- HOSE CLAMP
11617833646 --- AIR DUCT
11617833645 --- SUCTION TUBE
7119905016 ---- COUNTERSUNK SCREW --- X4
7119901780 ---- FILLISTER HEAD WITH WASHER
16131176747 --- PLASTIC NUT
7119931115 ---- FLAT WASHER ---- X2
7129952127 ---- HOSE CLAMP
11617833647 --- AIR SHUT OFF CALVE
11157833649 --- VENT HOSE
13717896774 --- INTAKE MANIFOLD
13621739510 --- TEMPERATURE SENSOR AIR
13727838625 --- BMC AIR PANNEL FILTER
Engine Modification
TCS497/C ------ Samsco Hoses
EV111AA Evolve- ECU Tune + Alpha-N Stage 3
E46M3CCK ----- Zionsville E46 M3 Competition Cooling Kit
E46M3CCK ----- Zionsville - SPAL (2) Speed Fan Kit
11317835041 --- CSL INLET CAMSHAFT
11317835043 --- CSL CAMSHAFT EXHAUST
11337833259 --- BMW Rocker Arms ---- X24
POWERPULLEY --- Rogue Engineering Power Pulleys
PD6002203R ---- Ignition Solutions PLASMADIRECT
--------------- Castrol Edge 10w-60 --- X6
11427833769 --- BMW Oil Filter Kit
54-10468 ------ AFE Cold Air Intake System Dynamic Air Scoop
OilCoolerKit -- E46 M3 Turner Motorsport Fluidyne Oil Cooler Kit
Exhaust
022 044 001 --- SuperSprint Step Headers (Version 1)
022 044 002 --- SuperSprint Metallic Cat System
022 787 503 --- SuperSprint Resonated X-Pipe
B5313.00832 --- Eisenmann Racing Exhaust
11627830667 --- Gasket Asbestos Free
Transmission
21532282549 --- CSL Expansion tank
41147896136 --- SMG Reservoir Bracket
TM-RED ---------- UUC Transmission Mount Bushing kit - RED
101-43SMG ----- ESS E46 M3 SMG Transmission Software
CHF11S ----------- SMG Hydraulic Unit Fluid
CSL Center Console
51167895578 --- Console-CSL
51167896362 --- Frame-CSL
51167896361 --- Frame- CSL
51167896956 --- Insert-CSL
51711904843 --- Blind plugD=23MM --- X2
34417896360 --- e-brake boot
51168235570 --- Bracket
7129901644 ---- Body Nut --- X2
71111180290 --- Sheet Metal Screw --- X2
Interior
51417896919 --- Door handle front left-CSL
51417896920 --- Door handle front right
REC-070-91-UU11 RECARO Profi SPG XL --- X2
REC-8025 ------ RECARO - Steel Adapter (Pair) --- X2
REC-8015 ------ RECARO - Slider Track Kit --- X2
Tule Fab Custom brackets to mount --- X2
Custom CSL Interior and Rear Seat Delete
3.91 / 4.10 - Differential Parts Needed & Upgrades
E46M3RP ------- Turner 3.91 Ring and Pinion
33121205138 --- securing plate for pinion
33121204657 --- crush sleeve
33107510289 --- output seals 2
TMK-HM803110 -- bearing race
TMK-HM803149 -- Inner pinion bearing
83222282583 --- BMW Differential fluid .5 Liter 3
TDR4675412 ---- Turner E46 Rear Subframe Reinforcement Kit
E36BUSHING ---- Ground Control Street Stability Kit
West Cost Diff - Gear install
CSL Front Bumper
51117896820 --- PAINTED FRONT BUMPER TRIMSILBERGRAU
51117896379 --- Aerodynamic cover, left
51117896380 --- Aerodynamic cover, right
51117895883 --- GRILLE, AIR INLET LEFT
51112695252 --- Flap, towing eye, primed
51118191149 --- Gasket 2125 MM
51118195297 --- Shock absorber front left
51118195298 --- Shock absorber front right
61672695531 --- Head Lamp Cleaning Container
--- Repaint / Color Match Front Bumper
CSL Roof Pannel
41007895382 --- CSL Roof outer panel in Carbon
41328242075 --- BMW ROOF BOW
51442699065 --- BMW Headliner ITSSCHWARZ
51442268975 --- BMW Frame
51448171515 --- BMW Metal Bracket
51448250118 --- BMW Plate Cover
--------------- BMW Epoxy
Exterior changes
63216937454 --- BMW Right Rear LED Light
63216937452 --- BMW Left Rear LED Light
BMSBUAAA7AS --- Stealth Auto Bulbs
51127897863 --- CSL Carbon Fiber Diffuser
41007895884 --- CSL Boot Lid
63267165646 --- Registration Plate Light --- X2
61130007449 --- Cable Socket --- X4
61131378149 --- 8connector --- X2
51147893655 --- BMW ///M3 logo
51148219237 --- BMW trunk roundel
51148209932 --- Trunk lid roundel grommet for the BMW roundel --- X2
46632347012 --- License plate holder grommet PLUGIN NUT --- X2
88100141709 --- FLAT WASHER A6/4 X2
51181813015 --- SCREW --- X2
61136931929 --- UNIVERSAL PIN TERMINAL UNCODED 3 POL
61130006664 --- PINCONTACT 0,75MM --- X2
Steering and Suspension
32132282642 --- CSL / ZCP Steering Rack (14.5:1 steering ratio)
2072.31 ------- Eibach Front Sway Bar
2072.312 ------ Eibach Rear Sway Bar
BMWControlArm - Ground Control E46 Rear Lower Control Arms
TCKR ---------- TCKR True Match S/A Coilover System (500F/600R)
TCKCC --------- TC Kline Racing Camber/ Caster Plates
Wheels & Breaks
TWH9905002-K -- Turner Motorsport 10mm Hubcentric Front Wheel Spacer Kit
36112282650 --- CSL Light alloy rim Front 8.5 JX19 --- X3
36112282999 --- CSL Light alloy rim Rear 8.5 JX19 --- X2
83.137.4700.82- StopTech Front Big Brake (4 piston / 355mm)(Yellow Calipers)
--- Stainless lines
--- ATB Super Blue
83.137.0047.82- StopTech Rear Big Brake (4 piston / 355mm)(Yellow Calipers)
--- Stainless lines
--- ATB Super Blue
CSL Air Intake
Engine Modification
Exhaust
Transmission
CSL Center Console
Interior
CSL Front Bumper
CSL Roof Pannel
Exterior changes
Wheels & Breaks
--- Stainless lines
--- ATB Super Blue
--- Stainless lines
--- ATB Super Blue
Love this car.
