My little slip at voort you cant see it but you can hear the mistake
E46 M3 track slag turned around in a day
I uploaded my Vbox data from 2 weekends ago at knockhill and compared with the CSL data from the other month. (my csl is std bar AP's)
The new car is 5mph slower up the main straight, 2mph slower on the back straight and slower by about 7mph down through Duffus.
Now a lot of this could be down to the fact I just need to learn how to drive this car as never had a car with anything other than near factory settings however I did think that with the spec of the car it would easily match the CSL times.
Saying that I've just discovered a Vanos issue so that might explain the lack of power.
All in all the CSL is superb out the box and a std M3 needs to work really hard to get anywhere close.
Originally posted by billyboysm3 View PostNot yet it isn't, it just doesn't handle the same, steering rack maybe, stiffer bushes and square set up, as per the video I was wrestling with the steering but was on 19inch rims, the Csl is complete out of the box, then intrax and bbk finishes it off.
This thing is stripped and doesn't have it, it's good but not like letting a Csl loose on track.
Going to run square set up next and see, I think I could do 2.12 at snett really going for it but miles off that big 2.10!!!!
Fucking mega times shimmy at Bedford and snetterton, really good bench mark and anyone that can get near them is a very good driver.
Going to make sure I get tuition from mike wilds at Bedford and snett
Just done 2nd track night in m3 first was a diaster due to wheels rubbing inner arches. Best time was 1.9 secs down on csl, m3 is 8 mph down on my best time on main straight in csl, 112 was max speed last night. Car is going well but water temp was a bit high but would drop down quickly after cool down lapOriginally posted by rstoughy View PostI uploaded my Vbox data from 2 weekends ago at knockhill and compared with the CSL data from the other month. (my csl is std bar AP's)
Remove Aircon and front pusher fan, install electric fan and switch and no water temp issues unless your stuck on the M25Originally posted by derek View PostJust done 2nd track night in m3 first was a diaster due to wheels rubbing inner arches. Best time was 1.9 secs down on csl, m3 is 8 mph down on my best time on main straight in csl, 112 was max speed last night. Car is going well but water temp was a bit high but would drop down quickly after cool down lap
