M3 CSL spec
    M3 CSL spec
    info
    Specifications
    Body No. of doors/seats 2/4
    Length/width/height (unladen)
    mm 4,492/1,780/1,365
    Wheelbase
    mm 2,729
    Track, front/rear
    mm 1,518/1,525
    Turning circle
    m 11.0
    Tank capacity
    approx. ltr 63
    Cooling system incl. heater
    ltr 10.7
    Engine oil
    ltr 7.0
    Transmission fluid
    ltr 1.9
    Final drive fluid
    ltr 1.2
    Unladen weight, EU1
    kg 1,385
    Max. load to DIN standard
    kg 415
    Max. permissible weight to DIN
    kg 1,800
    Max. axle load, front/rear
    kg 880/1,020
    Max. trailer load2
    Braked (12%)/unbraked
    kg –
    Max. roof load/max towbar download
    kg –/–
    Luggage compartment to VDA st.
    ltr 410
    Air drag
    cX x A 0.683
    Power unit
    Configuration/cylinders/valves
    Straight/6/4
    Engine management
    MSS 54HP
    Capacity
    cc 3,246
    Bore/stroke
    mm 87.0/91.0
    Compression ratio
    :1
    11.5
    Fuel RON
    98
    Output kW/bhp
    265/360
    at rpm
    7,900
    Torque Nm (lb-ft)
    370 (273)
    at rpm
    4,900
    Electrical system
    Battery/location
    Ah/–
    55/luggage comp
    Alternator
    A/W
    120/1,680
    Suspension
    Front
    Single-joint spring strut axle with displaced castor;
    small positive steering roll radius, compensation of transverse forces, anti-dive
    Rear
    Central-arm axle with longitudinal control arms and double track control arms,
    anti-squat and anti-dive
    Brakes, front
    Single-piston swing-calliper disc brakes
    Diameter
    mm
    345 x 28, vented
    Brakes, rear
    Diameter
    mm
    328 x 20, vented
    Driving stability systems
    ABS, CBC, DSC; M differential lock
    Steering
    Rack-and-pinion
    Overall steering transmission
    :1
    14.5
    Transmission
    Six-speed manual
    Transmission ratios
    1st
    :1
    4.227
    2nd
    :1
    2.528
    3rd
    :1
    1.669
    4th
    :1
    1.226
    5th
    :1
    1.000
    6th
    :1
    0.828
    Rev
    :1
    3.746
    Final drive ratio
    :1
    3.620
    Tyres, front/rear
    235/35 ZR19 / 265/30 ZR19
    Rims, front/rear
    8.5J x 19 EH 2 IS 44 alu / 9.5J x 19 EH 2 IS 27 alu
    Performance
    Power-to-weight ratio to DIN stand
    kg/kW
    5.2
    Output per litre
    kW/bhp
    81.6/111.0
    Acceleration
    0–100 km/h
    sec
    4.9
    Stand-start km
    sec
    23.5
    In 4th gear
    80–120 km/h
    sec
    5.0
    Top speed (3)
    km/h
    2503
    Fuel consumption (EU cycle)
    Urban
    ltr/100km
    17.8
    Extra-urban
    ltr/100 km
    8.4
    Composite
    ltr/100 km
    11.9
    CO2
    g/km
    287
    Other data
    Emission category
    EU3
    1Weight of car in road trim (DIN) plus 75 kg for driver and luggage.
    2May be increased under certain conditions.
    3Electronically limited.
    very good mark. what were all the options available for the csl
      Here you go dave
      Standard equipment – interior
      * Cloth Laser/Amaretta ‘Reflex Pur’ Anthracite
      * Anthracite Headlining
      * Individual high gloss satin chrome
      * Titanium Shadow Interior Trim
      * Chrome gear lever knob
      * 4 Seats
      * M Steering Wheel with switch for M Track Mode
      Standard equipment – exterior
      * M3 CSL specific suspension settings
      * M Mobility System to inflate tires
      * Tailgate with low loading sill and integrated rear spoiler
      * Front apron without fog lights, with extra air intake
      * Model designation M3 CSL
      * Choice of Black Sapphire or Silver Grey metallic paint
      * 19” M light alloy wheels ‘M3 CSL’ with Michelin Pilot Sport Cup tires
      No cost options
      * 19” double spoke alloy wheels style 67M
      * Auto air conditioning
      * BMW Business radio
      * No model inscription
      * Graduated tint front windscreen
      * Smoker package
      Cost options
      * Car alarm €430.00
      * Climate comfort front windscreen €230.00
      * Floor mats €100.00
      * Park Distance Control (PDC) €400.00
      * Rain sensor €110.00
      * Headlamp wash €260.00
      * (Bi-)Xenon headlights with headlamp wash €530.00
      * Single CD €100.00
      * Mini disc player €260.00
        youre a star :beer:
        air con as no cost option, i would have thought most cars would of had that then
          youre a star :beer:
          Only nutters that think the csl should be raw nothing added.
          Thats great if it is just a track car not for every day use.
          I wanted a csl with air con and zenon lights.
            so did I :blalalala: but beggers cant be choosers!
              great info
                Originally posted by sc_bmw
                great info
                You want to know we will find out for you
                :thumbs:
