Originally posted by chillo
retrofit brake kit bmw performance
I have to concur with 'chillo'.Originally posted by chillocsl doesnt have 6pot fronts and 2 pots rears tho??
The standard CSL brakes are just bigger discs on the front than the stock M3.
The are single piston, fully floating calipers front and rear.
I was running Pagid Blue pads on the front with an otherwise complete standard set up and it was a very good set up.
I have just upgraded to APs front and rear and the difference is massive.
Don't forget the other benefit of getting rid of the standard CSL brakes is to save a whole load of unsprung weight. Anyone who has compared the weight difference between one of the massive AP front calipers and a tiny standard M3 front caliper will know what I mean :wink:
Its not a straight fit,you need to get some brackets made up.Originally posted by born2boost View PostHi Guys...
Just want to enquire if anybody has tried fitting these brakes to a CSL?
If so, were there any benefits? Was it a straight fit??
Please let me know as there is a set of these 135i Performance calipers available pretty cheap here....
Also the discs are made all the same so the direction of the grooves/holes go oposite way round on each side of the car . Fitted a set on 135i and checked with parts department that only 1 part number listed for discs , dont think BMW thort about that properly .Originally posted by Bounce View PostIts not a straight fit,you need to get some brackets made up.
As Bounce said BMW dont sell mount brackets for E46 .
I think standard csl discs work ok with them.Originally posted by giraffe View PostAlso the discs are made all the same so the direction of the grooves/holes go oposite way round on each side of the car . Fitted a set on 135i and checked with parts department that only 1 part number listed for discs , dont think BMW thort about that properly .
Has anybody on the forum actually done the mod? And can give an opinion based on his experience with them?
I'm concerned about the brake bias difference if any when changing to these calipers?
Having brackets made up is not a problem, I know a guy who could make them up for me....
Just don't want to do the mod and then the brakes are worst than the standard stuff ?
