info request - how to remove the door trim properly ?
Thanks guys. Worked a treat! All pretty easy when I got into it. And a set of trim lever things make it really easy.
As above ^^^
Remove the cap and screw from behind the door release handle, remove both bolts from the main grab handle before prising off the trim from the bottom up towards the top. Once unshipped, don't yank it as you still need to disconnect the door release operating cable and speaker harness.
Re-fitting is the opposite of above.
Pretty sure this thread covered it:
https://nam3forum.com/forums/forum/c...mething-better
Originally posted by Chrispy View PostBumpy bumpy.
Have to do this on Friday... Tips? Is it just the screw on the handle and clips for the rest?
Bumpy bumpy.
If anyone is able to post some instructions and pics for how to remove the CSL door trim properly and with minimum chance of causing damage it would be much appreciated.
Also any pics of what to expect once the trim is removed would be great
:thumbs:Tags: None
