Brake pad wear sensors
    Has the CSL got front and back wear sensors for the pads. EBC have asked if I require any wear sensor leads for their Red Stuff pads......and I don't know
    yes 1 on the front and 1 on the rear :thumbs:
      think its front n/s and rear o/s
      but disconnected of you have AP brakes!!
        you can reuse the old ones
          Thanks all. Will re-use then.
            Can only re-use the old ones if you've not worn the pads right down to the point where it breaks the sensor. :whistle:
              Just loop it and discard ... the sensors are pointless ...
                Had the EBC red stuff fitted and although it's not a full on big break conversion like most of you guys go for I still cannot believe the diffrence from just upgrading pads....very happy.
                  How much were the EBC red pads Andy?? Where did you get them from??
                    From these - If you put 'scooby58' in the discount code box you get extra discount.
                    Upgrade your vehicle's braking performance with premium EBC brake pads and discs from EBC Brakes Direct. Explore our high-performance brake solutions for a safer and smoother ride. Get top-quality brakes delivered straight to your doorstep
                    You could also try Marks mates as these are even cheaper I think. I tried but couldn't get hold of them.
                    Livingston auto parts 01506 433909.
