does lid airbox stay closed with cold temperature?
    Someone should buy a Kreis-Seig... best sounding out there, goes from a normal exhaust to completely straight through at a touch of a button!
    As said before, BMSport removed my flap. Went from their lowest peforming CSLs to one of the best!
      Originally posted by BMsport.com
      The amount of air entering the engine is controlled by the throttle valves, not the flap and monitored by a MAP sensor.
      Kindly explain how does an individual throttle intake system operate on a MAP sensor without an intake manifold (to measure manifold absolute pressure??) - better still point to me an actual MAP sensor BMW part number on the CSL (I've yet to find one on realoem.com - and no not the one on the idle regulator lines - that controls idle). As far as I am aware the car runs without a MAF or MAP sensor - basically Alpha N tune on throttle position and air temp sensors.
      Actually, if you can throw up a dyno graph showing that there's no torque loss without the flap operating in comparison to one with the flap operating.
        Map sensor part no. 13 62 7 833 561. It fits to the air rail so feeds from each throttle body, part no. 13 41 7 833 597.
          That one's for idle control ... unless I am mistaken ...
            And even if it was alpha n, the air flow would still be controlled by the throttle valves, not the flap.
              This I agree with (unless the DME was clever enough to also read the flap actuator and run different mappings for an on/off position (unlikely I know) ... I just thought your MAP sensor comment was at odds to what I understood about the CSL fuel injection system.
                idle control part no. 13 41 1 733 090
                  Yeah I saw that ... cheers.
                  So the CSL is not a true Alpha N set up?? Or does the MAP sensor on the air line only come into play for idle control?? (what I had originally thought it did - otherwise it'd idle like crap ...
                    The map sensor and airtemp sensor are there in place of the MAF meter. I tried looking for a BMW tech module on it, but they only have an explanation on the MAF not the MAP.
                      hmmm ... I've been told numerous times that the CSL is Alpha N mapping - the MAP sensor on the air line is only in relation to the idle control - maybe I'll unplug mine and see if it still drives :-D
                      I am familiar with the MAP sensors on Hondas ... not so on BMWs seeing they are usually all MAF screens. However on Hondas, turning them into ITBs require a separate vacuum canistor (of a correct volume) to calculate for MAP reading (which the CSL does not have- if you still wanted to run the MAP sensor) - but a Honda on ITBs can be turned into full Alpha N mode (say via a Hondata S300) in which case you can do without the vacuum canistor and just run the MAP for idle purposes.
                      Maybe I am getting myself confused ...
                        If you unplug the map sensor, the car will still run, like if it had a maf, it would still run unplugged. With the technical advances of the ECU they will run with so many things unplugged like the crank sensor etc.
                          I did few weeks ago a mesure of the engine power on a power dynamic bench.
                          and the result was: 347 cv at wheels for 8000 tr/min with lid open but only 306 cv with it closed!
                          Lid didnt't open because of a defaillant sensor of the temperature gearbox. http://www.cslregister.com/forum/vie...918&highlight=
                          Maybe engine was also in security mode!
                          After repair the lid opened correctly to has today.
                          Doubtless the defect stayed in memory and affects has new the functioning.
                          I have to check connectors and return to bmw to make a control to erase défaults.
                            On a Honda it wouldn't ... hmmmm ... I am still not fully convinced that the car's fuel injection system is a MAP system rather than Alpha N - goes against the original marketing and subsequent informations I've seen and read for the car.
                            Any way, getting way off topic on this one.
                            Like I said before ... to be sure whether the flap actually does anything - a comparative dyno graph on one car with the flap operating and with the flap removed will put this myth to the grave.
