Originally posted by RichW
Oil levels
3 oil changes & level checked using dip stick. Electronic reading 0.7 every time & no change in normal or track driving. I would not like to see +1.0 on my car as I would suspect it has been over filled. Does anyone know how the system works (temp, time, level?) as it gives odd results e.g. it fails if you only drive short distances.
Not true on the S54B32 ... it's a semi dry sump system ... so being slightly full doesn't actually do anything - i.e. not a wet crank situation.Originally posted by benCSL View Postif you look your dipstick, you are over the maximum....it's not very good for a motor.
As for the accuracy of the computer read outs ... NOT VERY ACCURATE. On mine at least .. the short term readings are slightly more accurate than the long term readings in my opinion. But I personally never trust it and simply pull the airbox if I really wanted to check - can't beat a dipstick for accuracy. :thumbs:
ok so another question.......
the manual says to check using the computer when the oil has been warmed to normal temp, then left for a minute or so to settle. The long-term reading is taken reguarly be sensors in the engine (I think).
But what does the dipstick level show at max - cold or hot ?
My level was showing at +1.0 l which I thought OK, then after fiddling about with the dash buttons at the weekend to put the clock forward I noticed it is now showing -.- l. Have I managed to reset something? I also checked using the idling quick check and it shows +1.1 l. Should I be worried? Was going to get an oil change soon in any case.
Thanks
Mark
-/- oil reading
My electronic oil reading is showing -/- and has been for a couple of days now. I have tried to get a momentary reading, by holding the sport button for a few seconds but it refuses to read anything but the -/-.
I am pretty confident that there is plenty of oil in the car, last reading I remember was 0.9L but am now becoming slightly nervous about running the car if it is low.
I know I could check the dipstick thanks to Mark's DIY video but was wondering if anyone has experienced this before or knows how to reset so save me the bother!!
Any advice would be greatly appreciated.
Cheers
Sounds like a faulty oil level sensorOriginally posted by fergusgo View PostMy electronic oil reading is showing -/- and has been for a couple of days now. I have tried to get a momentary reading, by holding the sport button for a few seconds but it refuses to read anything but the -/-.
Cheers
Get it checked at bmw if you have bmw warranty :thumbs:
Was going to mention that too. In the 3 years I've had mine, I've never had to put any oil into her. I've done around 20K in those 3 years, not moon miles but not a garage queen either. :thumbs:Originally posted by shimmy View Post
I have never had to add a drop of oil between services even after a fair few days on track:thumbs:
The -:- thing seems familiar, I think I had a fault like that in my E36 once, and it was a faulty sensor that cost £100 to fix...unless you have BMW Warranty of course, :smt055
Mine was like this for about 10 days which I assumed was due to the low mileage I do (< 10 per day) and the computer not having the data to calculate a long term reading. Now back to + 1.0L which is what it was at before.Originally posted by fergusgo View PostMy electronic oil reading is showing -/- and has been for a couple of days now. I have tried to get a momentary reading, by holding the sport button for a few seconds but it refuses to read anything but the -/-.
Cheers
Try going for a longer run (that's when mine seemed to reset) although I could be talking utter p*sh!
I had issues in the recalibration state ( -.-L ) generating a short term reading as well but all OK now (fingers crossed). Is going in for an oil service this week in any case.
