Rear Spring
    ^ That could be your RTABs aswell mate. Does the car feel squirmish under hard accel. like its rear wheel steer?
      yes, it almost feels like torque steer but on a RWD car
        Thats it. Your bushes could be fine, there just alot of movement in the rear arms. Thats why alot of the lads go for limiter kits or poly bushes.
          Might see if the dealers will replace my bushes and if it is still the same then fit a limiter kit.
            It will be the same with another set of standard bushes! Go for the limiter kit!
              where is the best place to get the kit?
                CA automotive do one for about £50-70! :thumbs:
                  As above, or give a fellow CSLreg'r a turn Here
                  Alternatively, Poly bushes Here
                    how much more vibration do you get with poly bushes?
                      Never noticed any in Marks car.
                      It'll be more than OEM, but insignificant Id imagine.
                        thanks for your help all, i had my wheels off the other day and they looked ok, so ill stop being paranoid :thumbs:
                          Simpson Motorsport and they'll set the geometry nicely as well. Adviseable after bush changes.
                            Yes also as Alex says Simpsons will have the kits and can fit etc! :thumbs:
                              Any idea on price for fitting?
                                Well thats the new spring fitted under bmw warranty :thumbs:
