changing paddles
    changing paddles
    had my new paddles for about 3 weeks now and havent had 2 minutes to even think about fitting them. tomorrow i may get a small window of opportunity when i get to my stop over in north wales. what tools are needed so i can pack them in advance and change them when i get to my destination?
    cant check now as its pitch black.
    cheers! :thumbs:
    Installation Guide for SMG Paddles
    Tools required: Torx T-20
    Time required: +/- 5 minutes
    1.) Original OEM Paddles
    2.) Look behind the steering wheel, you will find the screw that holds the paddles to the
    steering wheel. Use Torx T-20 to take the screw out
    3.) You will see a spring sticking out from the steering wheel.
    4.) Put Paddles on proper position and put the screw back in using Torx T-20
    5.) Repeat for the left side. You are done!
      you're fookin ace!! :thumbs:
        Yes very easy!
        But if you have the New Carbon ones the holes might need cleaning out before fitting!:thumbs:
