car key battery
    tried the key on a journey and still no charge :banghead:
      Originally posted by J.D. View Post
      Sure is. One of the faster Black version's. Being prepped at the moment and pick her up once back from Holiday :drool::drool:
      Nice one mate! Get your name down for the Ring trip in July - Daz may have a spare slot... :thumbs:
        Always room for one more at the inn :whistle:
          Looks like you need a trip to BMW
            Already got a trip planned to Donny for the Moto GP that weekend:banghead:
              Is the key doing anything?? Does the other key work?? To attempt to code the key to the car try this..
              >Definitions: button 1 on the keys is the one closest to the metal part of the key (this is the door open button); button 2 is the middle button (the door close button).
              >1. Open the car doors using the remote function of your working key.
              >2. Get in and close (don't lock) all the doors.
              >3. Put the key in the ignition and switch momentarily to position 1 which is the first position when you turn the key clockwise. This is the accessory position. Don't stay in position 1 longer than 5 seconds; then turn the key back to the off position.
              >4. Remove the key.
              >5. On the key transmitter, press and hold button 2. Press and release button 1 three times within 10 seconds while still pressing button 2.
              >6. release button 2.
              >7. The system indicates re-programming by locking and immediately unlocking the door locks.
              >8. If you want to do more remotes, you must do each within 30 seconds of step 7 for the preceding key. You just need to repeat steps 5 through 7 for each key after the first. You can knock off a dozen keys if you want in a few minutes.
              Mine wouldn't allow the car to unlock the doors on the key button but would disarm the alarm!! The unlock function on the center console was also failing to work, but all locking functions worked correctly and this was the sign that the GM5 module was on the way out. Don't know if the coupe or the CSL uses the same module.
                no and yes
                Thanks, I will give it a go :thumbs:
                  >4. Remove the key.
                  I believe that the above may not be correct, as I have just had to do this with my keys, and the procedure that works is this one, much the same as above but the buttons as pressed above are the wrong way round
                  All your keys get reprogrammed at the
                  same time. Here is how it is done
                  4. Remove the key.
                  5. On the key transmitter, press and hold the unlock button. Press and release the lock button three times within 10 seconds while still pressing the unlock button.
                  6. release the unlock button.
                  7. The system indicates re-programming by locking and immediately unlockingthe door locks.
                  8. If you want to do more remotes, you must do each within 30 seconds of step 7 for the preceding key. You just need to repeat steps 5 through 7 for each key after the first."
                    :thumbs:
                    great info Duncan, now get back to work!
                      :thumbs:
                      Im at my desk as we speak ! Busy booking flights, ferries,for Ring trips, paying for TD's to Spa,organising my UK TD's, sorting spare pads etc.,reviewing my racing trolley jack purchase, and a host of other tasks essential to the well being and running of my Company !!:hahaha:
                        Ok so here is my first attempt at a detailed "DIY" thread, also if you mess up your own key trying to do this don't yell at me!:argue: So I have the 2 key fobs that came with my car when I bought it used. One I use everyday and the second one has had a dead battery since I got the car. When I...
