Search in CSL Technical Area only
CSL Register
CSL Register Main Discussion
CSL Technical Area
M3 18" inside size needed
Mark CSL
Sep 2007
04-13-2009, 08:02 AM
Help needed can any 1 tell me the inside size of the 18" m3 wheel in mm please
Mark :thumbs:
NZ_M3
Mar 2020
04-13-2009, 03:50 PM
Do you mean the offset or the wheel spoke clearance??
If it's the offset then it's the following:
8JX18 ET:47 for the fronts (+47mm offset)
9JX18 ET:26 for the rears (+26mm offset)
If it's spokes clearance then you'll need to provide where you want the measurement taken relative to the centre of the wheel.
Mark CSL
Sep 2007
04-14-2009, 12:54 AM
Thanks but it is the inside diamiter of the wheel to see if it clears my brakes
i need 450mm clearance :thumbs:
_Nathan_
Sep 2008
04-14-2009, 01:26 AM
Hmmm.
Well that is 17.7 inches so I don't fancy your chances.
The 355mm 6 pot AP kit only just squeezes in there (some people have had to remove wheel balancing weights to make them fit).
donkcsl
Member
Sep 2007
04-14-2009, 05:53 AM
bad news mark, 410mm at the front and 445mm at the back:bigcry:
Mark CSL
Sep 2007
04-14-2009, 07:49 AM
Thanks donkcsl
I tryed 1 today just too tight my brakes are too big ( now you dont here that every day :hahaha: )
Thats the 18" wheels and slicks out the window :banghead:
Nords
Jan 2009
04-14-2009, 08:17 AM
My 18" go over my APs without a drama, however I haven't changed the tyres since they arrived, hence someone could have put the weights on carefully...
