pf discs - urgent help please
    Hi,
    Just fitting a new set of pf discs can someone confirm which the direction of the grooves please
    thanks
    Derek
    Derek
    the grooves angle a backwards, opposite to AP discs
    so on top of the disc they are pointing to the back of the car
      Derek
      brilliant thanks for your help much appreciated:thumbs::thumbs:
        Hi Derek, please see pm I have sent, thanks
          discs
          :smokinf rear disks? where did u buy em from? how much? are they cross drilled?
            I think Derek has a set of PF front discs...
                its was front pf discs and pads i just fitted, car stops again its great,:thumbs:
                  So this is the right way round for AP discs?
                  (I'd hope so, looking at the source of the pic)
                    Yes thery are correct!:beer:
                      Thanks..mine due on next week, so just wanted to double check..chrs Dan
                        i only found out lkast week it is nothing to do with the grooves in the face of the discs BUT the viens in the centre of the two discs and the cooling!!!!
                        learn soemthing every day!:supz:
                          Co-ordSport is a supplier for motorsport and tuning workshops, race and rally teams that build cars on behalf of their clients.
                          for Rear PF disks, they are dimpled (not fully drilled) or grooved, you choose
                          let me know if you need the part number
                            http://www.coordsport.com/
                            I was told they don't do a PF rear disc
                              I've got them on, ask for E46 M3 rears - 328mm disks, same as the CSL, direct replacement, only the front disks are bigger on the CSL
                              and the PF rear disks, as far as I know, are the only 2 piece rotors available.
                              pics when new, front and rear, I may go for grooved when I replace them, only to see what the difference is as they have been outstanding disks :thumbs:
