AP floating disk upgrade
    God knows why you need them.
    Stock brakes are perfectly adequate
      Fuchs - give Shimmy his login back.
        Originally posted by _Nathan_ View Post
        Sure the Alcon stuff is good but reports from CSL owners will be more relevant than GT3 owners, different weight distribution, different size disks, different calipers etc etc.
        None of those points above have anything to do with durability of a brake disc when it's being eroded by a brake pad. Same car, PF or Alcon disc, and the Alcons last longer than PFs.
        Also, there are threads started elsewhere by GT3 drivers entitled "Alcon problems" which doesn't quite give the impression of good quality control...
        That's only one person - Daz - who has been the ONLY reported problem of Alcons as far as a search on the interweb goes. And he had his discs removed, skimmed, dismantled, and every kind of fiddling by non-Alcon suppliers so far apart from actually going to the suppliers of his disc or Alcon themselves. Don't go scaremongering shit like this. :banghead:
          PF are the best, AP and Alcon are second best
          ask Fuchs
            My point is that the CSL application is different to the GT3 application, the heat generated will be different, the cooling is different and the thermo properties of the disk will be different if it is a different shape and size.
            I'm sure they are good but until someone has run both on a CSL until they have worn out I can't see how you can say with 100% confidence that one will last longer than the other?
            If I were buying new I'd look at them certainly, having to remove the caliper to change the pads could be an issue for me as I imagine it is slower but other than that they look great, this thread is about replacing disks for an AP kit, is there even an Alcon disk available to fit the AP bell? If not the comments about Alcon are completely irrelevant anyway.
            PS. When unspecified "problems" with AP stuff is used as a selling point for Alcon it is only fair to point out that regardless of what you buy people can and do have issues.
              cant comment on Alcons on M3 but my AP discs on the front (two sets) both lasted 1 year, 20k miles and 17 track days
              MY PF discs on this year have so far done 5k miles and 13 trackdays but i seriously doubt they will do DOUBLE the AP above (2 years, 40k miles and 34 trackdays)
                I never got 20k miles out of a set of AP Disks! I am just a hobbyist IDIOT.
                  now i would never say that.........but i know someone who might:thumbs:
                    Changing pads on the Alcons is a caliper off job, but it's only one bolt to rotate the caliper out. It's still a very easy job on the driveway.
                    Don't know if there are any real "problems" with APs and they certainly wouldn't be my basis for not choosing them. But general consensus did say their discs were questionable at best in comparison to others, including OEM CSL discs. Alcons OTOH were a proven solution on my old GT3 and used just as successfully as APs in top flight rally and FIA GT motorsport. Certainly less reported issues compared to APs.
                    Amyway, getting back to the OP question: between APs and PFs, I'd probably choose PFs.
                      I haven't seen anyone advertising an Alcon disk for use with an AP calliper set up ?
                        Really? I've always had to undo both bolts to change the pads ... pain in the butt to be honest and almost impossible to do at the track if the brakes are HOTT!!!
