clutch slip
    Originally posted by SpineOnABap View Post
    Haha!
    That's the thing, it wasn't driven by them at all ... so whatever was done in the workshop sorted it. Must find out as it's been bugging me (and may help others of course).
    Erasing the fault codes etc etc can reset certain systems. Probably what happened in your case.
      Update….finally decided I'd had enough of the dreaded slur so booked it into Stockport BMW, they had previously recalibrated the clutch biting point but that didn't cure it, told them I thought it must be the clutch (45k miles on same clutch as far as I'm aware), the tech guy took it out and thought it was the diff, the clutch is fine, they phoned me up and said it was a warranty item so replaced it, got it back 3 days ago....I was a little dubious to say the least......day 1-took it out and it felt the same (very disappointed)....day 2-decided to give the
      SMG software a chance to learn the new 'non slipping' diff, hmmmm improvement, the waaaaarrrrrggghhhh ching into gear reduced.....day 3(today)-jesus H christ I've got whiplash!! Its banging into gear like it used to, only slight hesitation but I think that will be cured with a little more ‘spirited’ driving tomorrow morning.
      Will update tomorrow night with results, off to bed for an early start. :thumbs:
        that`s a result if it`s cost you nothing mines in at bolton getting clutch flywheel etc unfortunatly its costing me £1800:bigcry:
          Is that at a dealer mate? My local stealer has just quoted me £1140
          for a new clutch a new flywheel and a smg software up date!
            Ok People there is a problem that bmw are not going to sort now :bigcry:
            If you tell BMW to take the box out for clutch slipping and you are willing to pay for it as long as the clutch is worn below the limit thats fine.
            BUT and its a big BUT if it is within spec i want warranty or good will to pay.
            Thats how to tell bmw you want the clutch sorted as all the CSLs i have seen
            and thats a few with some at 54,000 miles and the clutch was fine but flywheel had burn marks on it warranty picked up the tab :thumbs:
            Cheers Mark CSL
              yes thats at williams and she said they`ve given me discount which one quoted you £1140 ill phone them tommorrow and get a writen quote and question the price.
                Cheers Mark CSL
                ive asked to keep the clutch, what would you do if it looks ok and they still want paying, pay the bill then send the clutch to warrenty?
                  No tell them you want to see the clutch and fly wheel before they fit the new items then if its fine go for the warranty :thumbs:
                  Not a penny till you have seen it :supz:
                  This could just be the tight Scot in me
                    Mine is showing sign's of this, didn't want to but might have to get it into Andy at Murkett's before the Ring/Spa trip, don't want to kill it over there!
                    My problem is the next inspection is due in around 5k miles and it's the bloody big one so I'll be getting it all done at once! lol
                      You won't kill it - it will get worse but I don't believe anyone has actually broken their car by carrying on driving it with the clutch slur?
                        ok, had another drive in it today, its miles better, almost sorted (more driving required), its also curred the lumpy setting off from stand still, when pulling away from the lights it would take sort of two attemps to get the clutch in, now its there first time.
                        I was quoted £1,225 for a new clutch, diff was done under warranty, i love the warranty.
                        If you have warranty get the diff replaced first and go from there, its sorted mine!
                        :beer:
                          Is clutch slur the same as clutch judder? I have noticed that from 4th to 5th and even more so from 5th to 6th there is a certain vibration on up shifts - sounds like a muffled burrrrrrrgh.
                          Do I have the same issue?
                          Kp
                            That doesn't sound good...!
                              Kp
                              Answer to your question- no
                              Sounds like you have an issue, do you have warranty?
                                Yes but I dont get it all the time, just every now and again.
                                Kp
