Will sparco seats fit on recaro side mounts?
    I have aftermarket recaro bases and side mounts, will sparco seats fit on these or will sparco side mounts fit on the recaro bases, any seat boffins out there?:bigcry:
    I have Recaro seats and bases Lawsy, if you need some dimensions mate i can check them out..... alternatively, just throw the seats between the runners and do your belts up tighter mate !!! Maybe you could get a pdf file or drawing of both sets of runners and compare them ?
      i have been told previously when i bought my recaro by a rally kit supply company that none of the seat brackets fit outher manufacturers seats BUT not proven so cant say for sure
        Bet Thorney would have a clue
          hed definitely know for sure.....
          than probably change his mind 3 months later or just after you buy the seats
            I wouldnt put a seat on a rail that wasnt meant for it, unless they are identical in every way, you dont want to mess about with stuff like that as if you had a bad shunt who knows what can happen.
