Pagid Codes for AP brakes
    Just found my brochure and for anybody wondering here are the shape codes for Pagid RS pads for your 5575 AP callipers
    Front AP
    E8018 (17mm) or at a squeeze E1903(18mm)
    please note E1538 are 25mm and WONT FIT
    Rear AP
    E1265 (16mm)
      Good stuff Sheik Shim, thx for taking trouble to scan and post ! Have a good week.
        Nice thread Shimmy.
        What about the CP-5555 calipers (18mm pad)?
          What about the whole fookin brochure Shim !:hahaha:
            :thumbs: :thumbs: :thumbs:
              I do have the CP-5555 for mine so I am not sure what's to make fun with :smt045
                what shape code pads do the CP5555 use front and back alex?
                AP page i guess is this one
                http://www.apracing.com/info/product...F%3E_2733_2715
                Not sure what the difference is but looks like discs are the same as CP5575 callipers but normal 18 inch M3 wheels dont fit so i wonder if CP5575 was produced because they wanted the OEM 18 inch rim market using them?
                    :hahaha::hahaha::hahaha::hahaha::hahaha:
                    youve got a lot to learn!
                    give these guys too much info and theyll be sellotaping EVO pads onto their Sierra callipers and Nova Race discs:bigcry:
                      I think (someone may want to check) but 1903 are the ones for the cp5555 kit, which fit at a push the cp5575 kit.:thumbs: when i searched your kit had evo all over it?
                        Originally posted by TMAQ View Post
                        I think (someone may want to check) but 1903 are the ones for the cp5555 kit, which fit at a push the cp5575 kit.:thumbs: when i searched your kit it had evo all over it?
                        yes looks like thats right so just a 1mm thickness change in pad
                        i think thye found out the CP5555 doesnt fit under OEM 18 inch M3 rims and adapted it to suit and hence the 17mm pads change
                          gotcha... all over it like evo brakes on a CSL.
                            Yes, the discs are the same. The CP-5555 is a bit bigger (and works with a 18mm thick pad while the 5575 works with a 17mm thick pad).
                            Also, I think the reason of the CP5575 is what you mentioned (to fit in OEM 18").
                            I am not sure about the pad codes (didn't investigate yet).
                            I did get a brand new set of PF pads with the brakes (from the nice Swiss guy that sold them to me). I will check later, when I am back at home.
                              on the AP site they mention 362mm discs with the CP5555, might fit (very tight)? 356mm are on my AP kit
